steve m
posted on 28/2/14 at 07:09 PM |
DPF problem on Ford Tdci
Hi All
I seem to be having a few problems with my 2.0 Tdci, as earlier today, on a cold start up, it sounded like a tin box full of nuts and bolts being
shaken about
Honestly, it was that dreadful!!
it also had an error message of "service oil"
yet parked all day at work, oil checked, and all fine and on the mark, start it up, and it seems to be fine ??
So, ive done some search's and it seems , I could have Dpf problems
So an an oil/filter change tomorrow, as its done about 5k since the last one , and I always change at the 5-6k mark anyway
and reset the message, as I can !!
Question, does anyone recommend any fuel additives, that I can add to the fuel, that will help in my quest to get the car running a bit sweeter or
are these "additives" just snake oil
My car is used primarily on pretty short runs and 10 min runs at any time, but does have a blast on a motorway now and again
any one able to comment or help appreciated
robocog
posted on 28/2/14 at 07:27 PM |
In the process of buying my first diesel car so its something I was getting concerned enough to Google
On the car I'm interested in (BM E30 320D) I know there are issues (amongst the myriad of others!!!) with the thermostats failing open - making
the regeneration not happen as the car never reaches full running temp
I also read that duff glow plugs can cause them not to go into regeneration mode
There are possibly other issues that will contribute
As the Bm doesn't have a full time dedicated temp gauge (other than cockpit temp!) and involves doing "button pushy stuff with
voodoo" to get it to show temps its not as obvious that they are not getting to full running temp
Not sure if the Fords are the same?
Ours will be subject to lots of short journeys with the occasional longer run - which has put doubts that its the right tool for the job in hand...but
others have assured me that it shouldn't be a massive issue as long as it is reaching full temp in good time and remaining there on a run (so I
will have to memorise the button push sequence to get into temp monitor mode)
Worst case scenario I did find a company advertising they have good sucess regenerating them on a rolling road - if that fails it would be a big bill
for a new one (or just gut it and remap and hope you don't get caught)
Going to watch the thread closely as no money has actually changed hands yet
Regards
Rob
mark chandler
posted on 28/2/14 at 07:47 PM |
I throw 250ml of quality 2 stroke into my old Volvo on each tank fill up.
Car runs smoother, quieter and gets about 2mpg more with this, although for me the main reason is to lubricate the clever bits as the car is worthless
so if the engine or injection goes its scrap modern diesel is very heavily refined so has zero lubricating properties, this protects the pump and
injectors but it does pay for itself.
[Edited on 28/2/14 by mark chandler]
posted on 28/2/14 at 07:54 PM |
I had a DPF regen failure on mine... ground to halt on the hard shoulder of the A1M and the nice AA man confirmed the dpf was blocked..
Sounds the noise may be an EGR error, I would check that first BUT keep an eye on th oil level, if it starts going UP thats the sump filling up with
diesel and points to the DPF...
How many miles has it done? DPF lifespan is a crap 60~70K..
posted on 28/2/14 at 07:55 PM |
Have you tried Castrol R in it? Just wondering if I could recreate the wonderful smell of my 2 stroke youth..
steve m
posted on 28/2/14 at 10:35 PM |
I have to admit the oil level was higher ( 5mm) than when I last checked it, months ago
but also the car was on a slight downhill slant
The Egr is blocked off with a plate, so not sure if that will help or hinder the problem
53k mileage
[Edited on 28/2/14 by steve m]
prawnabie
posted on 1/3/14 at 09:38 AM |
I know on ford/pug dpfs, there is a bag of red fluid that injects into the dpf filter, this only lasts so long and may be empty on yours.
[Edited on 1/3/14 by prawnabie]
me!
posted on 1/3/14 at 10:05 AM |
53k mileage
The EGR system is often used as part of the regen calibration, it helps control the amount of oxygen going through the system, which is quite
important when your DPF is at 600 degrees C. They can have 'thermal runaway' above about 650 deg C I think, this is not a good thing!
If I was you I would unblank the EGR, best case is that it has stopped trying to regen, else it could be trying to regen without all its actuators
available. DPF toting engines are best left alone, or have it removed completely.
During regen you can get fuel in the oil due to the extra quantity that is being added very late in the cycle. This could be the cause of your higher
oil level if it has being attempting to regen a lot. It could of course be that it was on a slope, give it a sniff to find out!
Volvorsport
posted on 1/3/14 at 03:29 PM |
The technical term is exotherming , most substrates will exotherm at 800
take it for a thrash , top the fluid up if necessary
www.dbsmotorsport.co.uk
getting dirty under a bus
brookie
posted on 1/3/14 at 03:51 PM |
Regards
Rob
what reg 320 u getting buddy
Volvorsport
posted on 1/3/14 at 03:55 PM |
You can get dpfs cleaned aswell
me!
posted on 1/3/14 at 07:22 PM |
They exotherm during a normal regen- an exothermic reaction is just one that releases energy in the form of heat, like when you burn anything, which
is exactly what you are doing. Thermal runaway is the technical term for when the reaction accelerates in an uncontrolled fashion.
Sorry OP. Did the oil smell of fuel out of interest?
steve m
posted on 1/3/14 at 07:27 PM |
No the oil did not smell of diesel, but the oil that came out was very watery/thin
the car has done about 30 miles today, and most of it over 3k so hope ive done enough to clean it out
zetec
posted on 1/3/14 at 07:33 PM |
Often glug a couple of gallons of my son's 2 stroke kart premix in the MK when left over after a day at the track, smells great and with popping
exhaust on overun just to complete the experience!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
robocog
posted on 1/3/14 at 09:21 PM |
Aug 2006 56 plate (so hopefully without steering lock issues and more robust swirl flaps?)
M47N2 engine
98k on the clock - it ate a turbo a couple of K ago and it got "sorted" and repaired at great cost
we are related to the current owner - who has gone for a 4x4 Rav4 this time round as his hobby is metal detectoring and has had the BM's stuck a
few times
Will get de swirl flapped and de runflatted fairly early into our ownership I suspect
Test drive showed up rattly windows - but as our current tintop is an E46 I already have a tube of gummiphledge
Fingers crossed it will be as reliable / trouble free as our current 3 series has been
(though no more freebie jungle juice from the yard - the trucks drink all the deisel scrapping vehicles can yield - so one less perk to the job)
Regards
Rob
[Edited on 1/3/14 by robocog]
brookie
posted on 2/3/14 at 04:26 PM |
M47N2 engine
few times
Regards
Rob
think that the one without the timing chain problem just check lt out buddy
