xico_ze54
| posted on 16/3/14 at 06:14 PM |
how to convert a car radio to 220V?
hi
I'm asking to the good people in LB who knows many things that I don't, if there is some kind of chip "converter" in a way to
re-use an old car radio in my garage.
that is because I got some old radios and many speakers too in cars I had before.
so I thought if there is a chip way to adapt one of these radios and a pair of old speakers in a way to have some music in my workshop.
certainly many of you have made that experience before, or saw something similar to that.
any ideas?
thanks in advance
Amadeu
[Edited on 16/3/14 by xico_ze54]
http://www.viseudesign.com/Sevenesque-36.htm
Macbeast
| posted on 16/3/14 at 06:26 PM |
Just buy a power adaptor ( what the Canadians call a wall wart ) giving 12 V and at least 1 A. Or a CB power unit, say 12V at 5A Make sure you
connect positive to radio fused wire and negative to the radio metal case.
xico_ze54
| posted on 16/3/14 at 06:32 PM |
the power off is in Ahmpers not in Watts? BTW: what is typical car radio comsumption? thxs
Slimy38
| posted on 16/3/14 at 06:34 PM |
I tried that, at low volumes I got huge mains hum, and at high volumes the power demand tripped the wallwart (my new favourite word, thanks
Macbeast!). The latter can be solved with a bigger power supply, but I wasn't sure how to sort the former. A car radio would never need to have
to suppress 50hz on the supply.
Personally my next approach would be to use a spare car battery, and just charge it back up every so often...
snapper
| posted on 16/3/14 at 06:36 PM |
Simple transformer
The sort that is used for scaletrics or model railway
Maplins will do a bench transformer you just need to look at how powerfull your radio is
I eat to survive
I drink to forget
luke2152
| posted on 16/3/14 at 06:39 PM |
I've got an old car battery that holds a little charge running a radio on my workbench and a small ebay solar panel on the roof to keep it
topped up
bi22le
| posted on 16/3/14 at 06:45 PM |
Several ways you can do this.
car battery and trickle charger.
PC power supply
transformer from various uses
consumption will be around 140w max I guess or 10A max.
Please read my ring story:
coyoteboy
| posted on 16/3/14 at 06:46 PM |
Wow, and I though I was cheap using a donated old stereo I like the waste not want not attitude here but question the sanity.
snapper
| posted on 16/3/14 at 06:47 PM |
Ahh
Just thought, options are car battery or car battery charger or trickle charger connected to car battery
Any of these solutions will power a car radio in a gatage
I eat to survive
I drink to forget
dave_424
| posted on 16/3/14 at 07:20 PM |
PC power supply, all the black wires are ground, all the yellow wires are 12v, green wire needs an earth to turn it on.
designer
| posted on 16/3/14 at 07:35 PM |
topped up
Ditto
britishtrident
| posted on 16/3/14 at 07:36 PM |
Waste of time and money.
[/I]
snakebelly
| posted on 16/3/14 at 09:58 PM |
I've used one of these to power a radio and the larger size to power 2 12v driving lamps in our blast cabinet .
UK Stock DC 12/24V Universal Regulated Switching Power Supply for LED Strip/CCTV
serieslandy
| posted on 16/3/14 at 10:30 PM |
I have AC Power Adapter Adaptor Transformer 12V 5A Imax B5 B6 Balancer Charger black OO | eBay
kletsgoo running a car stereo in my bathroom.
It works perfectly. Need I say anymore. Just make sure you have the correct (car) speakers.
morcus
| posted on 16/3/14 at 10:39 PM |
As others have said why? You can buy a regular radio for £5 or less.
