Author: Subject: Mondeo Mk4 ESP light
whitestu
posted on 2/4/14 at 02:47 PM Reply With Quote
I noticed today that when on full left lock my ESP light comes on and stays on. The car is a 2009 Mondeo 2.0TDCI.
I'm guessing at a faulty connection to the abs sensor. It only happens when putting full left lock on and goes off and stays off if the ignition is turned off and back on until turning very sharp left again.
Has anyone come across this before?
Stu
britishtrident
posted on 2/4/14 at 04:10 PM Reply With Quote
It will have active (Hall Effect) sensors, often problems with those are caused by wheel bearing problems, the wheel bearings a have a ferro magnetic rubber ring built into the seal.
These Hall Effect types can be very difficult to trace faults in without the diagnostic equipment to read the codes, for BMWs and Rovers I ended up building a breakout box so I could connect an oscilloscope and DMM.
[/I]
britishtrident
posted on 2/4/14 at 04:39 PM Reply With Quote
This might help BBA Reman Forum Mondeo 2007 ESP
[/I]
whitestu
posted on 2/4/14 at 08:40 PM Reply With Quote
Thanks BT, I'd seen some stories of corrosion of the wiring elsewhere so I'll have a look. I've ordered an OBD reader so will see if there are any fault codes that help.
Stu
adithorp
posted on 2/4/14 at 09:00 PM Reply With Quote
Most simple EOBD readers won't read ABS/ESP faults.
http://jpsc.org.uk/forum/
whitestu
posted on 3/4/14 at 06:24 AM Reply With Quote
Hope fully it will the ad says:
Reads and clears fault codes
All software supplied (32 AND 64 bit xp/vista/win 7)
ABS
Engine
Air Bag
Live data
It's this one on ebay:
Stuhttp://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=171248763362&ssPageName=ADME:L:OC:GB:3160
Stu
snakebelly
posted on 3/4/14 at 06:51 AM Reply With Quote
I have one of those lying around, your welcome to borrow it for the price of postage, used it on my 53 plate mondeo. haven't got rid because it also reads some systems on my 06 transit.
whitestu
posted on 3/4/14 at 08:03 AM Reply With Quote
Thanks for the offer, but I've ordered one now!
Hopefully it will help me trace the fault, though when I drove the car last night it was fine again!
Stu
