Author: Subject: 1.2 pinto sporting idle
kj
posted on 15/11/14 at 08:46 AM Reply With Quote
As title pinto 1.2 sporting new leads plugs no fault code but idle up and down sometimes between 1100 _ 900
Think about it, think about it again and then do it.
SPYDER
posted on 15/11/14 at 09:20 AM Reply With Quote
Assuming that you mean Punto and not pinto I would be checking for air leaks or cracks around the inlet manifold.
britishtrident
posted on 15/11/14 at 09:46 AM Reply With Quote
If no vacuum leaks try cleaning the throttle body and idle speed control valve with carb cleaner. Any attempt to slow the idle speed by adjupsting the idle screw will usually make things worse.
[/I]
davidimurray
posted on 15/11/14 at 10:49 AM Reply With Quote
Not sure if the 1.2 sporting is the same as the 8V but the wife's one does the same. I believe it is the idle valve sticking in the throttle body. The problem is they are pressed into the body so are not easy to remove. I cleaned it and it was fine for a couple of months and then started doing it again.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
