MikeRJ
| posted on 19/1/15 at 11:31 AM |
Any Smart car experts?
I'm in the middle of rebuilding the engine on a recently acquired Smart Roadster Coupe (for my wife) and wondered if there was any way of
visually inspecting the clutch for wear? The flywheel and clutch is all one part with no obvious means of disassembly and you can't see the
edge of the friction plate.
pewe
| posted on 19/1/15 at 12:12 PM |
Chap who is in the same Motor club as me runs one.
I'll see if I can find his contact details unless Loggyboy has Aarons contact info?
Cheers, Pewe10
olimarler
| posted on 19/1/15 at 12:32 PM |
I can find out for you! I used to be the smart and Mercedes product trainer for the UK.
Will make a call tonight
Oli
MikeRJ
| posted on 19/1/15 at 01:14 PM |
Thanks, I knew LCB would come to the rescue
MikeRJ
| posted on 20/1/15 at 04:58 PM |
I found this clutch change guide on FQ101.co.uk. Seems that
the clutch is just lightly pressed together and can be fairly easily dismantled by simply levering the two halves apart. Will have a go tonight.
