tegwin
posted on 1/9/18 at 02:13 PM |
Mot rules question.... warning lights
I am aware the wording changed recently but not sure what that means.
My van has a low oil pressure warning on the dashboard flashing . It’s a faulty sensor which is on order. Will this warning light fail the mot or
prevent the test being conducted?
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 1/9/18 at 02:31 PM |
I don't think so, as you won't fail for the engine management light being on but will probably get an advisory
[Edited on 1/9/18 by Mr Whippy]
Angel Acevedo
posted on 1/9/18 at 03:05 PM |
Does MOT requires a high power motor run?
If so, I would think they will confirm in some manner that they wont be held responsible if the engine goes bang...
tegwin
posted on 1/9/18 at 03:10 PM |
I don’t see why, other than driving the van into the Ramps that they would be revving the balls of it...!?
Angel Acevedo
posted on 1/9/18 at 03:13 PM |
I´m from Mexico, not familiar with MOT procedure.
black fingernail
posted on 1/9/18 at 04:20 PM |
I seem to remember a disclaimer was required so the nuts could be revved off of diesel engines, so the emissions could be tested, I don't know
if this is still done.
ian locostzx9rc2
posted on 1/9/18 at 04:55 PM |
Engine management light on is now a failure as for your oil warning light they could refuse to do the mot or emissions test as they need to rev the
engine for the emissions test .
froggy
posted on 1/9/18 at 04:56 PM |
Regardless of any waver the test station is liable for any damage caused from an emissions test , if it’s one of the vans that won’t rev when
stationary i doubt many places would worry about the warning light if there’s oil on the dipstick .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
posted on 1/9/18 at 05:25 PM |
The above should apply! A lad I worked with got a warning from VOSA even though the customer told the VOSA inspector he wanted his van tested so he
knew what work needed doing
obfripper
posted on 1/9/18 at 10:18 PM |
Is it a fiat qubo/fiorino/citroen nemo/peugeot bipper or other fiat derived van?
If so, the flashing light is indicating that the oil has reached the end of its service life (due to dpf operation) and needs changing.
If it is not due a service and has not done too many miles since last oil change, it may be that the oil degradation value has not been reset in the
engine management when serviced - this is separate to the service indicator and requires a suitable diagnostic tool to perform.
It's a usual for these vans to turn up for mot with flashing oil lights, so long as the engine has oil and doesn't have camchain rattle i
would test them as presented.
Dave
obfripper
posted on 1/9/18 at 10:41 PM |
Just to add, i have had several that have prematurely brought this light on, due to the dpf differential pressure sensor pipework being split and so
the dpf being in permenent regeneration which significantly reduces the oil life.
It is the flexible section of hose underneath the fuel pump area that splits, and requires a heat resistant hose to replace.
Dave
tegwin
posted on 2/9/18 at 09:25 AM |
Thanks for the comments chaps.
its a 2.5TDI VW T5 Transporter.... It is due an oil service... not sure how the oil pressure warning is derived but I am assuming its just a pre-set
oil pressure switch rather than anything fancy that is counting oil quality....
Perhaps the sensible thing here is to just get it dealt with before i MOT.... Ive already booked and paid for the MOT but hey ho.. its only 23
quid...
obfripper
posted on 2/9/18 at 12:09 PM |
In that case it is the oil pressure switch, it does have an oil level/quality sensor but that will illuminate the oil pressure lamp orange for low
level and reduces the service interval if the oil is below spec.
Dave
MikeRJ
posted on 2/9/18 at 12:27 PM |
That needs to be qualified. The test station is only liable if they did not exercise reasonable diligence. Revving the nuts of a diesel engine
without checking oil levels or ascertaining the service history would not showing due diligence, but they would not be liable for an otherwise
unanticipated engine failure.
froggy
posted on 2/9/18 at 01:05 PM |
The procedure is to ask the presenter if the vehicle has been properly maintained which isn’t practical . Had this discussion with a few different
examiners and the answers the same . Only difference now is you can refuse to test if there’s excessive smoke before the emissions test is carried out
. I stopped asking a long time ago as it just comes across as scaremongering fishing for Cambelt work
