Simon
posted on 15/9/22 at 06:59 PM |
Modern! master cylinders
I bought a budget Espace 6 months ago and really didn't test everything properly (at all!!)
Anyway, after collecting it, it started raining and the drivers blade kept falling off the windscreen - turned out to be the metalwork - two pieces
pressed together.
Anyway, when removing wiper mech from car I think I stretched the brake master cylinder warning light wire. The problem - the dash warning light has
finally decided to stay on which is somewhat irritating so I need a bodge (I fix properly when I have time, before next mot!!)).
So, does the light come on when there is constant current or when circuit broken.
gremlin1234
posted on 15/9/22 at 08:03 PM |
circuits like that are usually wired as 'fail safe', ie light comes on if circuit breaks/ connector not in place.
also its common for the light to indicate handbrake on
Simon
posted on 15/9/22 at 08:44 PM |
I suspected it might be like that, I may just join the ends together for the time being.
Thank you
perksy
posted on 24/9/22 at 08:10 PM |
Won't the MOT tester be looking for it to come on at the ignition key stage and then go off?
If it doesn't come on at all, it'll be a fail ?
daviep
posted on 24/9/22 at 09:21 PM |
Normally the handbrake warning lamp and brake fluid level switch share a warning lamp, so handbrake operation performs the lamp test.
Pretty sure brake fluid level warning lamp / switch failure is only a minor and not a failure item.
“A truly great library contains something in it to offend everyone.”
