kj
| posted on 29/7/10 at 01:41 PM |
Clio ABS
Any idea's Clio 2005 model 1.4, low milage no ABS light on but the brakes feel like the ABS is kicking in.
Checked the usual the sensor rings for damage or crap on them, pads ok discs ok not warped etc.
Other than get rid of it.
Think about it, think about it again and then do it.
smart51
| posted on 29/7/10 at 01:46 PM |
Are the tyres OK? Is the road surface OK? Are you braking stupidly hard? Are the brakes a bit grabby? ABS feeling like it it working and no fault
lamp suggests that the ABS is working. Whilst Renault may have tuned it to be a bit over sensitive, I'd check the foundation brakes, the tyres
and the driver to make sure they're working properly.
| posted on 29/7/10 at 02:44 PM |
A dead/dying wheel speed sensor can cause the ABS to operate prematurely.
[Edited on 29/7/10 by MikeRJ]
prawnabie
| posted on 29/7/10 at 04:20 PM |
You say the discs are not warped, but have you checked the run out?
Even genuine Renault discs are quite thin and it doesnt take alot of heat to make them judder.
kj
| posted on 29/7/10 at 04:39 PM |
Wife's car only does about 2 miles per day.
Any way you can check the speed sensor?
ernie
| posted on 29/7/10 at 07:12 PM |
had the same problem. The abs kicks in occasionally for no reason when braking
It's one of the abs reluctor rings(one on each wheel) looks like a cog on the drive shaft. inspect each one very closely for broken teeth, or in
my case the cog had fractured and was slipping round the drive shaft.
You can get a replacement, it fits like a starting ring gear.
My local one man band garage, changed the whole drive shaft for about £160
