Author: Subject: bad day in the garage
Irony
posted on 28/8/10 at 01:58 PM Reply With Quote
Started the final build of my engine today. Got my new tin gaskets out that someone gave me (who said they didn't intend to use them) and checked them over. There not new they've already been torqued down so are more or less useless. Jumped in the tintop and off to Rimmerbros for a new set. Merrily torqued the first head on and started the second. One of the main head bolts at 90nm suddenly goes TWANNNNG! I nearly shed a tear at this point. Got mad and went for a stomp round the garden. Calmed down went and took the head off to find the bolt had sheared of flush with the block. Another little emotional moment later I was thinking about taking it to a engine builders to get out when I noticed the bolt was loose and some twisting had it come right out with no thread damage!
Jumped in the tiptop to go to Rimmers again and buy another gasket and bolt. 20 yards down the road and warning cirens on the dashboard. STOP, COOLANT, STOP NOW. Reverse back to house pop the bonnet, no water. Topped it up and looked dismally and the fast dripping under the golf. I think its coming from the pump itself.
Thats put a total end to my engine building for the weekend. I am in a grump. Pah
Irony
posted on 28/8/10 at 02:00 PM Reply With Quote
And now the SWMBO has said, praps we can decorate the bedroom! Arggh
Ivan
posted on 28/8/10 at 02:26 PM Reply With Quote
Oh no - I wouldn't do anything on a day like that - it's just tempting fate
posted on 28/8/10 at 02:39 PM Reply With Quote
sounds like a mare of a day!
what golf is it? sounds like a knackered plastic water pump, not an uncommon fault
RichardK
posted on 28/8/10 at 03:08 PM Reply With Quote
Crikey, with luck like that I wouldn't risk going for a piss.
Rich
Gallery updated 11/01/2011
Werner Van Loock
posted on 28/8/10 at 03:10 PM Reply With Quote
id wonder why the bolt broke? only 90NM and still loose in the head???
http://www.clubstylus.be
Ninehigh
posted on 28/8/10 at 03:18 PM Reply With Quote
Could be worse water pump went on my last mondeo and the timing belt came loose with it. AA towed it to work and then I had to wait until missus finished work before she could pick me up.. And I still needed a new car
jollygreengiant
posted on 28/8/10 at 03:35 PM Reply With Quote
My comment to my wife would be,
'And after all the Sh!te that has happened to me SO far to day, you seriously expect me to START decorating our perfect space known as the bed room. So please do me a favour, make me a cup of tea while I contemplate what to order in for tea tonight so that you don't have to cook and risk me breaking something else.'
tomgregory2000
posted on 28/8/10 at 03:40 PM Reply With Quote
its loose because its not clamping anything
think about it as a nut on a bolt and it will all make sence
wilkingj
posted on 28/8/10 at 04:07 PM Reply With Quote
I wouldnt do anything else... Its tempting fate.
I have days like that.
Once I even did literally nothing, so I sat down and started (attempted) to play my didgeridoo (I'm crap really, but its relaxing fun, and is supposed to help my Sleep Apnoea).
I broke a front tooth when it colided with the wood!
Thankfully, I just glued it back in with superglue, and it lasted several years before breaking off again, so put it back in with superglue yet again.
Yeah... dont do anything, it will bound to go wrong. Give it a days rest and start gently on that day.
Usually for me things go wrong in threes... Did you have three incidents?
Hope all goes well, you will get it fixed eventually... Just dont give up in the long run.
Best Regards
Geoff
http://www.v8viento.co.uk
Mark Allanson
posted on 28/8/10 at 04:10 PM Reply With Quote
The bolt was probably stretched, bottomed out and couldn't do anything else except shear
001Ben
posted on 28/8/10 at 04:49 PM Reply With Quote
Your tooth?
Irony
posted on 28/8/10 at 04:56 PM Reply With Quote
Superglue?!? Now thats locost....
femster87
posted on 28/8/10 at 06:09 PM Reply With Quote
if it makes you feel better just sheared inlet manifold bolt into the cylinder head. tried everything so far its not moving. looks like head is coming off one of those days
