hillbillyracer
| posted on 23/12/10 at 10:48 PM |
It's been fairly cold where I work then!
Had a tractor to fix, a mechanical/hydraulic problem. it'd been in the workshop over the weekend so that's a day & half witout the
heater on in the workshop. We discovered it had done this. under that ice is a rad filler neck! Water pump locked up, hoses as hard as rock,
bugger!
blakep82
| posted on 23/12/10 at 11:33 PM |
ooh, are tractor engines as delicate as car engines? or will that melt and be fine?
________________________
hillbillyracer
| posted on 23/12/10 at 11:54 PM |
Much bigger & heavier, all-iron pushrod, just a similar thing bigger but it matters little, if the ice has nowhere to expand to it'll make
room! We built a cardboard tent around the engine & pointed the space heater at it, got it hot enough to lift the temp gauge a couple of notches!
I was worried & we could'nt run till I'd fixed the problem it came in for so once melted we drained it so it could'nt do it
again. A few days on I've finished the job & happy to say it looks like they've got away with it, run up to temp today & nothing
seems amiss!
gazza285
| posted on 24/12/10 at 01:18 AM |
A slight leak.
Our 10 tonne fork lift has a slight water leak, we top it up every day, so it has no antifreeze in it. It also has no core plugs in it now.
carpmart
| posted on 24/12/10 at 05:59 AM |
Lucky escape on that tractor engine then!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
hillbillyracer
| posted on 24/12/10 at 08:27 AM |
Apparently it had an overheating problem in the summer due to a blocked radiator & got topped up a fair bit with water & then forgot about.
This has few core plugs either as it's wet-lined & doesnt need them so the ice could'nt have pushed them out. I'm glad it
was'nt in for something cooling related as we'd been more responsible for it, my job was at the other end so we're in the clear!
nige
| posted on 24/12/10 at 09:05 AM |
if i dint know better gazza i would say that ice is from a burst supply to some cabins
adj to concast on tata steel scunthorpe
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
gazza285
| posted on 24/12/10 at 06:27 PM |
That's because I took the photo yesterday as I was driving round to the LAF1 and 2 control room
