Author: Subject: 14 tooth front sprocket ZZR1400
russbost
posted on 11/1/11 at 10:04 AM Reply With Quote
Hi all
Trying to get hold of a 14 tooth front sprocket for a ZZR1400, 2009, I want to drop the gearing a little (I currently have a 15t sprocket which is 2 less than standard) & really haven't got room for a much bigger rear sprocket without making substantial alterations around the diff.
I've done the usual searches, but can't find anyone offering 14 teeth, does anyone know of a specialist sprocket manufacturer who would do a bespoke job? I may want several if they can be done at reasonable money.
Russ
liam.mccaffrey
posted on 11/1/11 at 10:10 AM Reply With Quote
not sure what the centre mounting arrangement is but hbc gear stock all manner of sprockets including various 14t
linky
Build Blog
Build Photo Album
clairetoo
posted on 11/1/11 at 10:15 AM Reply With Quote
Problem with a 14 tooth sprocket is horrendous chain wear , don't know why but you
Will get very rapid wear with a 14...
Its cuz I is blond , innit
Claire xx
Will weld for food......
carpmart
posted on 11/1/11 at 10:21 AM Reply With Quote
Hi Russ
I use a 12T front sprockets on my Fireblade engined race car as my standard sprocket size. I also had an 11T and a 10T sprocket made, though these are a little bit out gearing wise. I can HIGHLY recommend JB Gears in Wetherby. 01937 845030. He does a lot of specials for the autograss lads and also makes a lot of gears for the bike race community as well. In my experience, his prices have been very reasonable.
HTH!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
russbost
posted on 11/1/11 at 10:58 AM Reply With Quote
Many thanx for the info - I already deal with John at JB gears; for some reason didn't realise he did front sprockets as well as rears Doh!!! Just rang him & he has a 14 tooth off the shelf, it's a grasstrack part!
Not too worried about chain wear, it's probably going to trash chains fairly quickly anyway!
MikeCapon
posted on 11/1/11 at 04:06 PM Reply With Quote
14 toothers should not lead to excessive chain wear. Only when matched to rear sprockets with tooth numbers that are multiples of 14...
minitici
posted on 11/1/11 at 04:38 PM Reply With Quote
As above - don't use two even numbered sprockets.
Use an odd & even or two odds to ensure even wear on the chain.
