Author: Subject: Pinto -v- Duratec + 40 -v- 45 Carbs
posted on 16/8/13 at 08:00 PM Reply With Quote
I feel that Dan is threatening my 'change-of-plans' title, so I'm sniffing around another kit to bump up my figures!
The only thing that I REALLY don't like about this particular kit though is the 2.0 Pinto engine in it. It's heavy, not particularly powerful and not particularly frugal (which is important as the car would be doing the commute all year round).
The most obvious engine swap is a Duratec (inlet / exhaust on the same sides and it mates easily enough to a Type 9). I would want to keep it on Carbs though to keep the swap costs down, so I guess the first question is... would a Carb'd 2.0 Duratec be any more frugal than a similarly Carb'd Pinto? Or more thirsty???
The second question is... the Pinto is on Webber 40's. Would these be a suitable to swap onto a Duratec, or would it be better off with 45's?
Over to you folks...
It's Evolution Baby!
big_wasa
posted on 16/8/13 at 08:51 PM Reply With Quote
Daily driver and you want webers nonono.
You want nice factory fuel injection
I will be the first to ask what's it going in ?
posted on 16/8/13 at 08:57 PM Reply With Quote
Hmmmm.... factory FI you say? Hadn't thought of that. I'd just thought about super expensive aftermarket ITB stuff!
So, are Fords (say an ST150) ECU relatively straightforward to use when the engine is no longer inside it's intended application?
PS - can't say what it is yet as Dan might nip in and buy it from under my nose!
big_wasa
posted on 16/8/13 at 09:08 PM Reply With Quote
I've not done an st150 yet, vid above is an st170 (my current/last project). St170 is way more complex than the st150 and although its says Duratec, it isn't.
The ecu has an immobilizer other than that its just an ecu like any other. There are a few more connections than others due to sequential injection.
As per vid, It just works. just preaching the word
posted on 16/8/13 at 09:19 PM Reply With Quote
You may have a convert!
big_wasa
posted on 16/8/13 at 09:26 PM Reply With Quote
Now if you go zetec I have posted an how to if your good with wiring, and an ecu can be had for a tenner.
There is a breaker that does the st170 ecu for £20
snapper
posted on 17/8/13 at 06:25 AM Reply With Quote
Curated ECU has PATS and needs to see the Ford dash amongst other stuff
You can run the original FI with Megasquirt
I eat to survive
I drink to forget
big_wasa
posted on 17/8/13 at 09:19 AM Reply With Quote
My vid above for a 2004 ford st170 shows it doesn't need the dash. Is the duratec / mazda system different ?
