Author: Subject: Zetec fan switch
mattycoops43
posted on 26/6/15 at 07:35 PM Reply With Quote
Zetec fan switch
Hi guys.
Is there a temp switch that will screw into the 17mm thread hole from the top ecu sensor on the thermostat housing?
big_wasa
posted on 26/6/15 at 09:19 PM Reply With Quote
Fitting should be 3/8 npt. Ecu would switch the fan as standard. Most use an m22x1.5 switch in the rad or somthing els in the top rail. Or an aftermarket ecu can also switch it via a relay.
