ragindave
| posted on 7/8/17 at 12:07 PM |
ORQUE ANDROID Super Mini ELM V2.1 OBD2 OBDII Bluetooth Adapter Auto Scanner
Has anyone used one of these are they any good?
TORQUE ANDROID Super Mini ELM V2.1 OBD2 OBDII Bluetooth Adapter Auto Scanner
loggyboy
| posted on 7/8/17 at 12:33 PM |
I use similar, works fine on the Clio for datalogging and reading/clearing most fault codes.
Mistral Motorsport
| posted on 7/8/17 at 12:50 PM |
It will probably work okay but these adaptors are very hit or miss one of the problems is the pins on the connector are not the correct size as it
result they tend to be a very loose fit in the OBDC socket. Very carful bending of the pins can usually get them to work.
