Davegtst
posted on 30/6/10 at 04:50 PM |
Anyone know where you can get baffles from? Seems like nova racing don't answer emails too quickly so i can't see what their design is
like. Does the powertec one give much clearance? It looks like it's a bit bigger than the others.
richard thomas
posted on 30/6/10 at 08:04 PM |
Re Powertec sump - I kept the engine quite low in the chassis for bonnet clearance, but have about 4 fingers clearance to the floor from the
sump....which isn't to bad given previous posts. Never grounded it yet, including speed humps.
[Edited on 30/6/10 by richard thomas]
Davegtst
posted on 2/7/10 at 02:51 PM |
Thanks for that Richard. Still not having much luck, no one wants to answer emails and holeshot seems to have dissapeared.
Rustybin
posted on 2/7/10 at 07:24 PM |
Thanks on the accusump advice.
Regarding sumps, you might want to give Westfield a bell. They do a dry sump which is quite expensive but also a wet sump which is a purpose built
casting plus baffles that should fit any sump. They don't bother with a swinging pick up, just cut down the existing. Powertec just cut the
bottom off the sump and weld a plate on which reduces oil capacity where the westfield solution increases it.
Chet
posted on 2/7/10 at 08:11 PM |
Dave-
You have a MSG.
Chet
