NigeEss
| posted on 12/10/11 at 09:29 PM |
quote: Originally posted by tomgregory2000
quote: Originally posted by NigeEss
I've got a 300tdi with autobox in a Disco I'm scrapping.
It's got the edc pump which can be made to work in a 90 or stick a manual one on.
Open to sensible offers.
Ive got myself a 1995 disco as my donor that came with 12 months mot and 6 months tax so am running that as my everyday car till i need the bits from
it, so its a no from me
Can't blame me for asking
Is yours the EDC pump ? I've a fair bit of info for making that work.
Do your tyres scrub the chassis on lock and articulation with having the Freestyle alloys ? Mine did
so I've had to fit 30mm spacers. Using 235/85 tyres.
tomgregory2000
| posted on 13/10/11 at 08:40 AM |
Its not got the EDC pump which was a nice supprise but even if it was i have the 300tdi that im removing from the 90
With the grizzly claws i did catch the radius arms but no body contact, with the alloys on there is no issue on body or chassis but i have 30mm
spacers fitted and have adjusted the stops on the hubs
edit: mine has a 2" lift
[Edited on 13/10/11 by tomgregory2000]
tomgregory2000
| posted on 23/10/11 at 12:31 PM |
well i thought i would give a little update while at work
the start of removing bits off the bulkhead ready to be removed, they are heavy enough on there own
start by removing the pedals
and just like that the brake pedal is off
and now off with the clutch
And removing the wiring
Almost ready to remove the bulkhead
And look its off
tomgregory2000
| posted on 23/10/11 at 12:35 PM |
Its not looking too bad and rather sound, lets see if we can find any rust (there has to be some it is a landy after all)
Oh look what i found on the offside front out rigger
BUT the rest looks very sound which was a nice supprise
Just everything has a nice light coating of mud
tomgregory2000
| posted on 23/10/11 at 12:42 PM |
Now with the bulkhead off the next challenge was to remove the steering wheel, was a bit of a b1tch to remove
Two home made pullers later and lots of swearing and
Now i can remove the switch gear and look at removing the steering colum
And its all off
tomgregory2000
| posted on 23/10/11 at 12:50 PM |
And about this time i bought myself a rather nice mig welder and then set to work looking at the "rust" issue
Now i have not done any welding in 8 years, the last welding i had done was back at college
First job is to remove the rust back to good metal
Im doing it in 2 pieces as there is a kink along one side
The first plate goes in
And then time to fit the second one
And then grind it all flat and make it look good
tomgregory2000
| posted on 23/10/11 at 12:55 PM |
So lets take a look at the back end
I was planning to remove just the rear crossmember and replace that so lets see what hides under the multipull patches
Its not getting any better
So i decieded to remove the whole thing
Before
After
Can you tell the difference?
tomgregory2000
| posted on 23/10/11 at 01:17 PM |
With the back end removed i decieded to make my own replacement with the help of the old man so while that is getting punched out ill remove more
bits
Off with the dampers
Fuel lines
and then time to remove the bits still attached to the engine
Almost free, just the oil cooler lines
Then out with the rad and intercooler
And off with the slam pannel/rad support
More good condition chassis
tomgregory2000
| posted on 23/10/11 at 01:26 PM |
The start of the replacement crossmember
First job is to weld on the tabs that fix onto the rear tub
FINISHED!!!!!!!!!!
yeh right
but it proves it fits and my measurements were correct
Time to prep the chassis for the extensions
Removing the outer skin of the chassis
Mock up just to make sure its all going to fit
And my towbar fixing spreader plate that is going to be fitted to the inside of the crossmember
tomgregory2000
| posted on 23/10/11 at 01:29 PM |
Time to look at getting the engine and box out as the weather is good
it was a case of removing the engine and moving the chassis out of the way and then plonking the heavy engine and box straight down
Look no engine
tomgregory2000
| posted on 23/10/11 at 01:32 PM |
Went off to the 4x4 clearout at newbury and got myself an good condition bulkhead, only £265
almost no rust on this one
tomgregory2000
| posted on 23/10/11 at 01:37 PM |
Now its time to look at the gearbox crossmember and see what lurks behind where it fits to the chassis as rust likes to form between the mating
surfaces
crossmember out
its a good job im not using this one
ns chassis rail
not too bad bit of surface rust but nothing major
os chassis rail a different story
there should only be 4 holes in this section, not 5
Might as well remove the gearbox mounts as well
tomgregory2000
| posted on 23/10/11 at 01:42 PM |
Lets get the hole repared
weldings getting better
and grind it flat
stand by for more updates
Wheels244
| posted on 23/10/11 at 01:52 PM |
Looking good
You've made a good job of the rear crossmember.
I've just fitted a Disco rear axle for better brakes after reconditioning it.
I had to buy two new Terrafirma shocks thanks to the previous owner cross threading one of them leading to shearing of the threaded spindle on one of
them.
I fitted a new adjustable A frame ball joint - and yes, the old one was a bitch to get out.
Made up and fitted new rear brake pipes.
Once that was done, I was turning the Landrover around and the steering drop arm ball joint shears - 5 hours to change yesterday ! You might want to
look at yours whilst you've got such good access.
I put the finishing touches to it this morning, did a safety check, greased the prop shafts and steering arms etc then took it out for a test
drive.
And then the clutch starts slipping ...............................
| posted on 23/10/11 at 03:02 PM |
What size are them BF's on it at the moment please?
tomgregory2000
| posted on 23/10/11 at 06:51 PM |
the bf are no longer on it, sold um to a mate to fit on his disco, they were 245/75/16 about 31" overall height
too small for a defender but a nice size on a disco.
Its back to the 305/70/16 grizly claws while i work on it
| posted on 23/10/11 at 08:48 PM |
My friend's lad rebuilt a series 2a onto a galvanised chassis and replaced the engine with a 200tdi, I wired it for him with a new loom and some
other bits. He can't afford to run it yet as he is not 18 till later this year and it's a lot of money to insure him.
tomgregory2000
| posted on 25/10/11 at 08:32 PM |
Another little update
Reinforcing plates inside the rear crossmember
extensions taced in place
And all welded
tomgregory2000
| posted on 25/10/11 at 08:39 PM |
Now on with the back plate, no mud traps for me thank you
And these are the jacking tubes and end covers
Jacking tubes welded in place
And the back plates in place, welded and blended in
And the front of the jacking tubes ground down
tomgregory2000
| posted on 25/10/11 at 08:43 PM |
And now for the reinforcing plates
And fully welded in and plug weld holes drilled
tomgregory2000
| posted on 25/10/11 at 08:45 PM |
now its time to fix it on to the rest of the chassis
MakeEverything
| posted on 25/10/11 at 09:41 PM |
Good bit of fabrication there mate. Spot on.
Kindest Regards,
Richard.
bertie_bas205
| posted on 26/10/11 at 03:03 AM |
It's a labour of love huh???
I have a few Landys myself.....
I dunno how to put pics up on here...
Are ye on the DIFFLOCK forum??
Keep up the good work,
Bertie.
blakep82
| posted on 5/1/12 at 06:33 PM |
any more photos?!
________________________
T66
| posted on 5/1/12 at 08:01 PM |
Reading this thread again, I really want another Landy.
Coming along really well
