<<  1    2    3  >>
Author: Subject: My new project Land Rover 90 (its not a defender)
tomgregory2000
posted on 5/1/12 at 08:18 PM Reply With Quote
i will try and update soon, have made some progress but not as much as i would have liked though
tomgregory2000
posted on 9/2/12 at 09:37 AM Reply With Quote
Ok, ive managed to finally get some more photos from my camera onto my computer and then onto here
Now im a little disappointed with the progress but its taking longer than planned
More welding of the rear end, these are the towbar brackets
Ive yet to do the welding on the underside of the chassis, this will be done when i flip the chassis over
tomgregory2000
posted on 9/2/12 at 09:41 AM Reply With Quote
Now time to look at the new engine mounts (i hope these are in the correct place)
Old ones removed
Cleaning up and marking out for the new ones
Tack in place
And then fully weld in, no going back
Once agen the underside will be welded once the chassis is flipped over
tomgregory2000
posted on 9/2/12 at 09:47 AM Reply With Quote
Now its time to remove the old axles
These ones are 10 spline axles and wont be used as i have a nice set of 24 spline ones from my donor disco
First off with the springs
One free axle that just rolls out of the way
Now time to remove the rear axle
One chassis, no axles
And as if by magic the chassis is flipped over (its a little heavy)
And welded on the underside
Hugh_
posted on 9/2/12 at 01:32 PM Reply With Quote
Stunning, note to self, must do a landy project at some stage
MakeEverything
posted on 9/2/12 at 01:45 PM Reply With Quote
Me too, when iet my 200m2 workshop after the lottery win!
Kindest Regards,
Richard.
tomgregory2000
posted on 9/2/12 at 01:51 PM Reply With Quote
You do needs LOADS of space,im using half of my back garden, garden is about 80' x 30' and half of the single garage. There are bits of landy everywhere
Ive got more photos to go on tonight as that progress only takes me upto the end'ish of last year.
tomgregory2000
posted on 9/2/12 at 07:27 PM Reply With Quote
Ok, more update
Oh no where has my chassis gone
Oh well lets go off roading till i can find my chassis, where did i leave it.....
Right now i must try and find my chassis, its not the smallest thing to loose
tomgregory2000
posted on 9/2/12 at 07:30 PM Reply With Quote
IVE FOUND IT!!!!!!!!!!!!!!!
mmmmmmmmmmmmmmmmmmmmmmmmmmmmm shiny galvanised sexyness!!!!!!!
tomgregory2000
posted on 9/2/12 at 07:33 PM Reply With Quote
Now its time to hide the silver galvanised surface with a load of black paint to make it look as factory as possible
Im missing some pics of it the other way up
omega 24 v6
posted on 9/2/12 at 07:35 PM Reply With Quote
More photo's more photo's NOW
tomgregory2000
posted on 9/2/12 at 07:45 PM Reply With Quote
Now with the chassis done its time to look at the axles which ive removed from my disco donor
I had the axles shot blasted and hot zinc sprayed, got to do things propperly and all that
A few suspension components that have been painted
And my new cranked trailing arms, thank you mr gwyn lewis, these are monsters, twin wall with a propper lifetime warranty
First coat of thinned paint
And now with the top coat
tomgregory2000
posted on 9/2/12 at 07:50 PM Reply With Quote
These are the rear hubs just cleaned up and painted and fitted with brand new genuine wheel bearings
One side complete with drive shaft installed, 24 spline and nice and strong
And now for the other side
Yep it looks just like the other one
tomgregory2000
posted on 9/2/12 at 07:53 PM Reply With Quote
Nice new a frame ball joint fitted
these require a 20ton press to fit, the one that i have fitted is adjustable and greaseable so as it wears i can nip it up
tomgregory2000
posted on 9/2/12 at 08:02 PM Reply With Quote
Time to fit the rear axle to the chassis
First job is to put some wheels on it (i will not be using these tyres)
On with the trailing arms
Fitted with new galvanised spring seats
And on with the new +2 springs (with the mandatory doing some work picture)
Fitting it to the chassis, as you can see the marquee that i was building it in seems to be missing , it got damaged beyond repair in the strong winds at the begining of the year
Thats all for now
omega 24 v6
posted on 9/2/12 at 08:12 PM Reply With Quote
Hope you are going to keep us updated.
I WANT ONE
Bluemoon
posted on 10/2/12 at 09:42 AM Reply With Quote
I like the hot zinc spray something I thought of doing on the Indy chassis, found someone that would do it as well, wished I had (add's some weight and makes welding a PITA latter though)..
[Edited on 10/2/12 by Bluemoon]
SeaBass
posted on 10/2/12 at 11:10 AM Reply With Quote
I'm lusting after a 90 ATM... I must be getting old. A mate keeps whispering Land Rover in my ear everytime I see him.
blakep82
posted on 11/4/13 at 08:43 PM Reply With Quote
Whats happened?! Whats going on? News please!
________________________
Bluemoon
posted on 12/4/13 at 09:09 AM Reply With Quote
Tea break? Most projects seem to have one...
TimC
posted on 12/4/13 at 03:39 PM Reply With Quote
I'm still wrestling with selling my SIII 88". It hadn't run for two weeks up until last Sunday and I needed to take rubbish to the tip - it started in a heartbeat as it always seems to. Great trucks. I can only imagine that the coil-sprung models are even better.
If I didn't have a kit car project, I'd be doing a retro-style Landy.
DarrenW
posted on 12/4/13 at 04:40 PM Reply With Quote
Seems to be a bit of time lag / thread revival here, but a great resto project nevertheless.
Ive got a fully rebuild and re-chassis'd 90 Defender. Fantastic vehicle but probs going to sell it soon.
<<  1    2    3  >>
