<<  1    2    3    4  >>
Author: Subject: Blade turbo
welderman
posted on 28/2/07 at 08:02 PM Reply With Quote
any paticular make or are they the same.
Thank's, Joe
I don't stalk people
the_fbi
posted on 28/2/07 at 08:11 PM Reply With Quote
I wouldn't cut a corner on a gauge. Autometer (not Autogauge) are good quality and cheap from USA via eBay.
You may struggle to find one which gives you a 9-10 psi max, or even 1 bar, and you don't really want a 2+bar unit as you'll never use more than 1/3rd of it.
Autometer do a 20psi unit as their lowest afaik.
Shouldn't be more than £8.00 posted from the US and the gauge will only be £23 on the current exchange rate. Similar gauge in the UK will be an easy £45 + delivery.
May be some cheaper 2nd hand on eBay or other forums.
dilley
posted on 1/3/07 at 01:28 PM Reply With Quote
I have an oil filled gauge that I got from holeshot, its suppose to be megga, I only changed it because Im running turbosmart e-boost which has a digital read out. I also have a another gauge both are as new condition.
[Edited on 1/3/07 by dilley]
welderman
posted on 1/3/07 at 02:15 PM Reply With Quote
Does that mean you may have one for sale Mr dilley.
Thank's, Joe
welderman
posted on 1/3/07 at 02:22 PM Reply With Quote
also do i need to get the exhaust gasses out asap, ie if i have two exits one 50mm and the wastegate is 25.
I can weild a 75mm tube over the 50mm and 32mm over the 25mm hole so it escapes quiker or do i just stick with a 50mm one and 25mm one.
These exit pipes will be joined after about 60 mm. Rescued attachment d9_1.jpg
Thank's, Joe
dilley
posted on 1/3/07 at 07:59 PM Reply With Quote
Yes I have got 2 gauges for sale,
Do you have an exhaust flange for the
turbo??
welderman
posted on 1/3/07 at 10:11 PM Reply With Quote
dilley, might be interested in a guage, and yes just this second finnished the flange.,
Thank's, Joe
dilley
posted on 2/3/07 at 07:46 AM Reply With Quote
what did you dicide to do on the exhaust, I wasnt too sure when you asked
welderman
posted on 2/3/07 at 12:11 PM Reply With Quote
[Edited on 2/3/07 by welderman] Rescued attachment exhaust3.jpg
Thank's, Joe
frankycopp
posted on 5/3/07 at 03:50 PM Reply With Quote
is there anyone that would make a turbo kit for me?
quadra
posted on 5/3/07 at 06:42 PM Reply With Quote
I have a 2wd sierra cosworth intercooler that used to be on my Dax Rush, it fits inside the nosecone above the radiator. Are you interested, its in good condition. I have upgraded to a larger intercooler as I am running 25psi now.
Mike
You don't need eyes to see, you need vision!
dilley
posted on 5/3/07 at 09:54 PM Reply With Quote
25psiall the time?
Simon
posted on 5/3/07 at 11:07 PM Reply With Quote
Renault 5GT T intercoolers, with plastic bits removed, and ally welded on instead. Also changed the flow from in and out at same end to straight through.
I/c's were about a fiver each
simon
quadra
posted on 6/3/07 at 12:32 PM Reply With Quote
Boost peaks at 25psi and then holds about 22psi, certainly shifts.
Mike
mb893
posted on 7/3/07 at 05:25 PM Reply With Quote
Welderman,
U2U sent... Sorry for the delay, only just noticed I had a message :-)
[Edited on 7/3/07 by mb893]
welderman
posted on 11/3/07 at 09:02 PM Reply With Quote
mb893, thanks mate not been on for a few days myself. Ta for the info.
Joe
Thank's, Joe
welderman
posted on 11/3/07 at 09:03 PM Reply With Quote
simon
Bloody hell wicked man.
Thank's, Joe
G.Man
posted on 11/3/07 at 09:15 PM Reply With Quote
simon
Looks a nice construction, as a subaru owner tho, can I say heatsoak?
Make sure you have good scoops
Opinions are like backsides..
Simon
posted on 11/3/07 at 10:59 PM Reply With Quote
No worries about heat soak. Air in at top, through i/c's then vented out of sides (these are ducted under coolers). Note side panels are proud for air extraction with forward facing vents for air entry (primarily for air to filters). There's a vent on top of bonnet behind rad, and nose section slightly wider to allow for air extraction
Maybe a bit of overkill
Simon
[Edited on 11/3/07 by Simon]
welderman
posted on 12/3/07 at 08:41 PM Reply With Quote
blimey theres alot of filler in that, hope i dont have cooling problems cause if i do might run it without the bonnet on,
Thank's, Joe
dilley
posted on 12/3/07 at 08:58 PM Reply With Quote
Im still having some issues with mine, I think I may have sorted it now,just...££££new rad
welderman
posted on 12/3/07 at 09:38 PM Reply With Quote
so did your set up from holeshot not come with a diferent rad.
Oh and your on for the trip just need to find time, but over 3 weeks is better for me, ta for that too.
Thank's, Joe
Simon
posted on 12/3/07 at 11:49 PM Reply With Quote
Err, the bonnet has been turned into the buck. It'll be moulded, then I'll make a new bonnet.
But you knew that, didn't you
Simon
dilley
posted on 12/3/07 at 11:53 PM Reply With Quote
No I didnt gt a rad from holeshot, cooling both oil and water is something that needs looking into on all turbo becs, next stage for me is to find out what my intake temp is.
welderman
posted on 14/3/07 at 06:53 PM Reply With Quote
Simon
did you not fancy cutting some hose with some gauze over them
Thank's, Joe
<<  1    2    3    4  >>
