froggy
posted on 23/6/11 at 12:20 PM |
The only difference I can see between my set up and others is the vgt turbo where with the vane fully open I get backpressure ratio of 1-1 where boost
and back pressure are equal . I assume this is possible due to the massive turbine housing which is believed to be 25cm 3 or a/r of nearly 2.0 which
is very unusual . It certainly feels like it wants to hold well over 2bar as it is rock solid up to
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
coyoteboy
posted on 23/6/11 at 01:30 PM |
Time to crack out my differential gauges!
turboben
posted on 23/6/11 at 02:52 PM |
That turbo sounds awesome is it a standard part or from a tuning company?
froggy
posted on 23/6/11 at 03:58 PM |
The turbo is a he351 vgt holset normally fitted to dodge ram diesels . There are a few people in the us trying to come up with a useable solution to
controlling the sliding vane but it's such a huge turbo its hard to find room to fit it in a normal front or rear drive car .
coyoteboy
posted on 23/6/11 at 04:09 PM |
ffffoooodge me, that's large.
[Edited on 23/6/11 by coyoteboy]
froggy
posted on 23/6/11 at 05:40 PM |
thats a 431ve which is a bit smaller than the 531 heres mine
heres the vane control set up with a pair of actuators ,the left is a vacuum actuator to pull the vane open under vac conditions for low egt etc and
the right one is boost fed to push the vane open as boost rises
cosworth yb rod compared to the saab b204 rod
quite a bit heavier too
pretty strong either way round
i did step up to 870cc injectors and ran 2 bar but ran into a few issues with boost control so the motor is back out again
Xtreme Kermit
posted on 23/6/11 at 07:03 PM |
Nice rod, shame about the piston
turboben
posted on 23/6/11 at 07:17 PM |
That turbo makes my subaru td05 look like a toy!
froggy
posted on 23/6/11 at 07:22 PM |
Holset vgt vs tdo4 19t
Although it has a variable vane there is a limit to how low it can spool purely down to the fact that it has journal bearings and the sheer size of it
[Edited on 23/6/11 by froggy]
CNHSS1
posted on 26/6/11 at 10:51 AM |
with regards to the scepticism of the deka 630cc injectors and their ability to support the bhp quoted, has anyone thought that the manufacturer may
have aired on the side of caution with the 630 designation? maybe like the SAAB parts, they too are a bit over engineered or not got the added boy
racer BS factor added (this air filter will give ya anova 50hp mister...)
if its making the power on a reputable dyno and the AFRs are sensible, it makes the power-end of.
froggy
posted on 1/7/11 at 06:02 PM |
dash ready for drilling big holes in
froggy
posted on 6/7/11 at 05:40 PM |
a few more oles
froggy
posted on 20/7/11 at 07:10 PM |
bit more done
ashg
posted on 20/7/11 at 08:21 PM |
froggy do you need to find a home for the td04?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
froggy
posted on 20/7/11 at 09:01 PM |
long gone mate and not a big fan as i broke two 19t hybrids trying to push past 300hp due to shaft flex .
zilspeed
posted on 25/7/11 at 07:59 AM |
Neat work Froggy.
That looks the part.
froggy
posted on 2/8/11 at 06:19 PM |
red is chargecooler blue for engine coolant
froggy
posted on 3/8/11 at 06:08 PM |
I'm expecting a cease and desist letter from ariel any day now lol it's a hariel katom
froggy
posted on 6/8/11 at 02:03 PM |
few more bits done and he wiring starts on monday
froggy
posted on 18/8/11 at 04:59 PM |
decided to move up to 15" wheels to give room for brake upgrades if needed plus much greater tyre choice .
froggy
posted on 28/8/11 at 05:20 PM |
bit crowded round the turbo but i have a big heat shield to go on to keep the bulkhead from melting
tank back in and now i need to work out if there is anything to be gained by directing the hot air from the rad out of the wheel arches or up through
some holes in the bonnet ,i had no issues running the twin bike engines with an uprated micra rad but i think there will be a lot n=more heat to deal
with from the new set up .
[Edited on 28/8/11 by froggy]
OX
posted on 28/8/11 at 06:18 PM |
looks great dude
nice work
froggy
posted on 27/9/11 at 05:25 PM |
http://youtu.be/N3Ms0mPJSDQ
a few niggles to deal with but the hardware seems to work ok . im seeing a few psi of boost from the turbo with no load on too which is a good sign
T66
posted on 27/9/11 at 06:18 PM |
Froggy - It just gets better whenever you post....
Brilliant
Proby
posted on 27/9/11 at 07:46 PM |
Awesome work! First time I've seen this thread as I'm pretty new on here, and I've just read it start to finish!
