bart
posted on 11/3/15 at 01:48 AM |
Nice lathe
Make a good job of the slides and nuts and it will out live you
Consider covers ion to quick change tool post. Worth it in the long run
BE ALERT > BRITAIN NEEDS LERTS
Rosco86
posted on 20/3/15 at 07:26 PM |
quote: Originally posted by bart
Nice lathe
Cheers pal, yeah it's on my never ending list!
Rosco86
posted on 20/3/15 at 07:36 PM |
Well the lathes almost there, new motor fitted, just a bit of wiring up to do
Also I've got my exhaust back all welded up
Going to use these rubber mounts I think
I'm a little worried about the clearance between the exhaust and my grp side panel, the gaps 15mm at the min
I'm happy with the silencer position though
Can anyone comment on my clearance issue?
bart
posted on 20/3/15 at 07:51 PM |
Nice lathe
Nice exhaust
Looking good
big_wasa
posted on 20/3/15 at 08:34 PM |
Lathe looks great.
Rosco86
posted on 24/3/15 at 10:22 PM |
Cheers guys
Rosco86
posted on 30/3/15 at 07:53 PM |
A bit of an update tonight, I was looking on speedhunters today like I do most days, and they decided to do a little wright up with some pictures I
sent in
http://www.speedhunters.com/2015/03/iamthespeedhunter-your-bike-powered-builds/
It's about half way down
Next on the list, the lathes all finished
Also I'm back on my pedal box, should get it all tacked up this week
Clamping the sides up square
Pedals
Flange bearings for the pivots
All the tubes will be tig welded in
And that's it for now
Andybarbet
posted on 30/3/15 at 08:07 PM |
Oooooh - I like that a lot :-)
rdodger
posted on 30/3/15 at 08:56 PM |
Very nice!
Rosco86
posted on 1/4/15 at 09:18 PM |
A bit more done tonight, I made some exhaust hangers at the weekend and my rubber mounts came today so got it all mounted and tacked up
Pretty happy with how it's worked out, sits where I want it to which in good
[Edited on 1/4/15 by Rosco86]
Rosco86
posted on 6/4/15 at 04:10 PM |
Had a good few days on the car this weekend, got a bit done
Pedal box tacked up and in the car, there's still a bit to do on it but at least I no where my seats going
Front seat rails done, I've raised the front of the seat to lower the harness holes at the rear
Nuts welded underneath
Harness mounting bosses made
Rear diagonal done
A shot from the rear, also a bit of artwork put up!
Also I've set my self a date of Easter next year to be Iva'ed and on the road
Rosco86
posted on 12/4/15 at 12:46 PM |
This weeks progress
I started working out where my lower harness mounts were going according to the msa blue book
I've changed the book design a little, tacked in
Centre two
Upper seat brackets done, I no the top edge doesn't need a radius behind the seat, but it looks neater I think
Just need some side to side spacers sorting and some correct length bolts
Next throttle cable sorted and temp return spring and the studding through the top is a temp forward stop
Full throttle
Clutch cable
Full clutch
I made two tubes to hold the outer cables
Next job, the rest of the roll cage, I've decided to mount the front hoop on the outside, as bashing my leg on it all the time not my idea of
fun
I mocked up the scuttle panel, and worked out a mounting plate
The tube will mount to a bit of tube on end with two more bolts so it meats msa spec, once the front hoops in place I will sort my roof bars and door
bars out
[Edited on 12/4/15 by Rosco86]
davidimurray
posted on 12/4/15 at 02:25 PM |
Be careful with those upper seat belt mounts. I can't remember if you're going for IVA, but if the belts touch the seats they will fail.
Mine are on a cross bar on the roll hoop about 4 inches higher and it was just right for IVA.
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Rosco86
posted on 12/4/15 at 05:10 PM |
Dave
Yeah im going for iva, ive tilted the seat back a bit and the mounts are going to have a spacer ontop to bring the mounts up a little, they dont need
a lot
Rosco86
posted on 13/4/15 at 07:03 PM |
Just been looking at my front roll bar hoop, I think I'm going to mount it on the outside i think and welded on, I've had a quick draw up
of it, but I'm going to mock it up with plastic pipe while I'm sat in the car
![](http://i133.photobucket.com/albums/q62/
corsaboss/lathe/6C6D8FB1-0FC4-41FB-BDFE-D8F0759ECDDA.jpg)
CosKev3
posted on 14/4/15 at 09:16 PM |
Nice.
Have you planned for a stop on your clutch pedal?
As you can pull bike clutches too far when using a pedal.
Rosco86
posted on 14/4/15 at 09:44 PM |
quote: Originally posted by CosKev3
Nice.
Cheers, yeah I'm going to have an adjuster in the backplate on the clutch and throttle, and forward stops,
Does anyone no if you need a forward stop on your brake?
Also when I put the engine in first gear the output shaft obviously is turning the engine instead of spinning but when I dip the clutch it
doesn't spin
Rosco86
posted on 26/4/15 at 05:33 PM |
Good progress the last few weeks, pedal box and pedals are getting finish welded and then off for powder coat
Front hoop in position, roof bar in plastic
Side mounts
Door bar mocked up
Exhaust altered and posted back to my mate to tig weld
Door and roof bars fitted, notching the door bars what a bit tricky to get them both the same!
Rear diagonal redone in 45mm cds
corsaboss/lathe/8EA4CDB2-6BC7-44B8-9981-27C6AA61BCA0.jpg)
Rosco86
posted on 9/5/15 at 08:22 PM |
Bit of an update, didn't have much to do last week, I went stonleigh and brought all my lights,
Made these threaded slugs
Drilled and fitted here
Rear spoiler held in position
More slugs made
Stays made
All done
I no some people won't like it, but I got the spoiler for nothing, it's only for a mess about, that's why I've done it to bolt
on and off easily
Today's job was to start making a bead roller like below
Bits required
Machining the blocks to house the bearings on my dad's home built cnc
Last up my dads started on my dash buttons, we're having a go using an ARDUINO, it's a programable chip with ins and out, they can be used
with switches, sensors, relays just have a look on ebay to see what's available, the boards are about £8 and everything else like switches are
pence, it's programmed from a PC through USB, so things like indicator flashing can be programmed, if it works out ok it will all be soldered
and put in a little project box
corsaboss/lathe/9368B1E4-7357-46BF-9ADC-EF2F08D87EEC.jpg)
dubzter
posted on 10/5/15 at 08:41 AM |
Awesome work, not sure about the spoiler but it will be good to see it once there is some bodywork in place.
I've been looking at Arduino for building a boost type gauge for my other car, should be a nice cheap control unit for what you are planning if
it works out.
_______________________
Blog
Facebook Build Thread
Haynes Forum Build Thread
Locost Builders Build Thread
Lew The Machine
posted on 14/5/15 at 09:49 PM |
looking really good dude! I'd keep the wing, looks awesome! although i think the stays could do with a few tweeks!
I've just finished Uni for the summer so hoping to make some decent progress on mine over the next few months!
Pedal box looks INSANE... pretty sure you could sell those all day long!
Keep it up!
ITS FINE! i welded it!
Rosco86
posted on 15/5/15 at 06:39 PM |
it works out.
Yeah that should be doable, I'm sure you could get a pressure sensor linked up, I've got my dad on it so see how he gets on
Rosco86
posted on 15/5/15 at 06:40 PM |
Keep it up!
Cheers pal, what do you think needs doing to the stays then?
Cool, get cracking then!
Lew The Machine
posted on 15/5/15 at 09:30 PM |
Keep it up!
The angles of the stays look like they're "triangulated" the wrong way?
I can see why you need the distance between the top stay and the bolt as the acuteness of the angle would stop the bolt coming out, but the bottom one
could be much nearer the bolt head?
It just "looks wrong" and as most of the guys at work tell me... If it looks wrong it usually is!
It's a minor detail though and the whole build is beyond awesome!
I'm doing my best to play catch up... But I'm being side tracked by real life, buying a house! Solicitors don't appreciate that I
need time in the shed haha!
Rosco86
posted on 16/5/15 at 07:59 PM |
Yeah I see what your saying, it's because that's how long the tube was that I used lol, I didn't want to buy any as it's only
for a mess around, I'm going to put some fancy laser cut gussets in it I think
