Author: Subject: Home made bonnet 'catches' possible?
John.Taylor
posted on 18/4/09 at 01:23 PM Reply With Quote
SVA on Monday and I can't find my bonnet catches, realised last weekend and ordered new from company who will remain nameless but they haven't arrived in todays post and that was the last chance.
I need to make something but would a couple of strips of aluminium strips riveted down in place of the missing catches, plus numerous spares for during/after the test be ok? If not, would bolts & nut covers instead of rivets be ok? What other alternative do I have?
mookaloid
posted on 18/4/09 at 01:37 PM Reply With Quote
I would have thought anything which will hold the bonnet down without sharp edges would do. - a couple of bungee cords might be ok
Bear in mind that you will have to remove the bonnet at the test.
John.Taylor
posted on 18/4/09 at 01:56 PM Reply With Quote
Ali strip would be filed and sanded to chamfer and rivets are domed and could have a blob of PU to fill the hole. Would this be ok?
Gary 7
posted on 18/4/09 at 01:57 PM Reply With Quote
I would add some small pieces of angle or bent strip to the top chassis rail ,then using self tappers fix through the bonnet to the angle brackets,you could use plastic number plate screw covers to hide the fixing.Dont make the holes to big ,and try and make the hole were you need the catches to be.
John.Taylor
posted on 18/4/09 at 02:03 PM Reply With Quote
Genius, prize goes to that man - got welder, angle iron and screws!
stevebubs
posted on 18/4/09 at 03:32 PM Reply With Quote
Any local dzus suppliers?
speedyxjs
posted on 18/4/09 at 04:27 PM Reply With Quote
Well there goes my suggestion of welding it on
Il get my coat
James
posted on 18/4/09 at 05:20 PM Reply With Quote
None of the builders near you able to lend you a set?
James
Valtra
posted on 18/4/09 at 11:48 PM Reply With Quote
You may find something suitable in HALFRAUDS on a Sunday
but as they say Necessity is the mother of invention
good luck with the test
"If it looks like it works and it feels like it works, then it works"
