gordon h
posted on 9/5/09 at 05:14 PM |
mk wheel et
can anyone help, am running 15 6.5j et 38 wheels need to fill out back arches will 15 6.5 or 7 et 45 fit ok. what are you running.
bec is best but going to try sabb 2.3 turbo mk
Chippy
posted on 9/5/09 at 05:26 PM |
Hi, ET 45 wheels will just make the problem worse, you will need to reduce the ET, how much depends on the amount that the wheels need to be drawn
out. The alternative is to just fit a set of spacers, probably the easiest option. HTH Ray
[Edited on 9-5-09 by Chippy]
gordon h
posted on 9/5/09 at 05:33 PM |
my 6.5 et38 sit flush with arche which is ok but got plenty of room back to shock,tried 7 et25 and trye sits past arche no good.
Chippy
posted on 9/5/09 at 09:52 PM |
I would say that if the tyre fits within the arch then dont change it, because nothing looks worse than having the wheel back in the arch, looks
really crap, like you couldnt afford the right size wheels, ![](/images//smilies/bigsmile.gif) Cheers Ray
