Poll: MK Indy Engine Options [View Results]
Volvo T5 engine
Pinto
2nd hand zetec
new zetec
<<  1    2  >>
Author: Subject: MK Indy Engine Options
Dan.
posted on 17/9/09 at 06:38 PM Reply With Quote
Hi all,
I have recently purchased a part built indy and I am looking to choose an engine for it.
I have narrwed it down to a list of 4 but feel free to throw any other suggestions into the mix.
1) Volvo T5 engine & box, chipped to 300HP £500-700 (no heavier than a pinto too!)
2) 2nd hand pinto obviously cheap & I have gearbox already
3) 2nd hand zetec, cheap again and box will fit.
4) new zetec £700 off ebay
The original plan was the T5 lump as it offers silly power cheaply, however having spoken to th previous owner of this indy he did not think it was such a good idea to run that much HP in a 7, he stated others who run big HP often are no quicker (or slower) than people running less as they constantly spinn up the rear tyres.
Anyway if anyone who has run big HP in a 7 could comment on their experiences too it would be appreciated.
flak monkey
posted on 17/9/09 at 06:40 PM Reply With Quote
Duratec...need I say more?
Sera
http://www.motosera.com
Staple balls
posted on 17/9/09 at 06:41 PM Reply With Quote
The zetec wouldn't be one from robinkitlolocostpartsdirecthood, would it?
Not sure how they are on engines, but they don't have a good reputation for anything else.
Dan.
posted on 17/9/09 at 06:44 PM Reply With Quote
from here... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260475702427&ssPageName=STRK:MEWAX:IT
mookaloid
posted on 17/9/09 at 06:45 PM Reply With Quote
Beat me to it again David
t16turbotone
posted on 17/9/09 at 06:48 PM Reply With Quote
Stick with your origonal plan...remember this simple equation, more power = more fun
posted on 17/9/09 at 06:56 PM Reply With Quote
BEC
Phil
PAUL FISHER
posted on 17/9/09 at 06:58 PM Reply With Quote
T5 turbo,go for it,and have some fun
Staple balls
posted on 17/9/09 at 07:01 PM Reply With Quote
The T5 strikes me as a very silly idea.
Do it.
DRC INDY 7
posted on 17/9/09 at 07:14 PM Reply With Quote
CEC
It's the only way plus you get a free reverse gear
Puddle Dodgers Club
Dan.
posted on 17/9/09 at 07:24 PM Reply With Quote
looks like the T5 is winning so far, anyone who has answered had a 7 with similar power?
Edit: you guys are a bad influence...
[Edited on 17/9/09 by Dan.]
FASTdan
posted on 17/9/09 at 07:52 PM Reply With Quote
Ignore the 'spinning up the tyres' stuff......usually spouted by low powered, stuck in their ways owners lol.
saying that, my personal preference would be 200bhp, 4 cylinder NA in a 7 .
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
tomgregory2000
posted on 17/9/09 at 08:04 PM Reply With Quote
Turbo power all the way!!!!!
YeeeeeeeeeeeeHaaaaaaaaaaaaa
afj
posted on 17/9/09 at 08:17 PM Reply With Quote
well i vote for none of the above and say honda s2000
eerrrrrrrrrrrrrrrr
Blackcab
posted on 17/9/09 at 08:19 PM Reply With Quote
Most of the components you have will be fine up to and a little over 200bhp, go for the Zetec, my new one has the 2.0 zetec and its plenty fast enough
Hope you managed to unload it ok
posted on 17/9/09 at 08:26 PM Reply With Quote
IIRC matt_claydon and Benzine on here both swapped from Pinto to T5 motors in their Indys.
Might be worth contacting them for some first hand info.
That said my choice would be a new Zetec.
martyn_16v
posted on 17/9/09 at 08:37 PM Reply With Quote
XE, clearly. Anyone who says different is simply insane
graememk
posted on 17/9/09 at 09:00 PM Reply With Quote
nissan ca18det, comes with gearbox too
RK
posted on 17/9/09 at 09:07 PM Reply With Quote
second the ca18det, although it does take a lot of room, it is cheap to put 300 HP out of it apparently. Standard form without the 2 1/2 " exhaust and cold air intake, you get about 170.
LBMEFM
posted on 18/9/09 at 05:35 AM Reply With Quote
You da man Hellfire, BEC BEC BEC BEC BEC BEC BEC BEC BEC BEC BEC BEC BEC BEC then you will have lots of these when you drive Barry (Who wants to go backwards - anyway the only way is forward)
Davey D
posted on 18/9/09 at 06:26 AM Reply With Quote
If going Turbo it say SR20DET from a 200sx.
If staying n/a, then get a 2.0 duratec mated to MX5 gearbox
DarrenW
posted on 18/9/09 at 01:12 PM Reply With Quote
Im not voyting as its up to you what you go for. However one piece of advice i would say, speaking from experience, is go for the engine you really want now rather than later.
I fitted a pinto with a view to going 16V later, big mistake as i ended up spending too much on the pinto by the time it had bike carbs, full exhaust, rebuilt and ported head etc etc. I could have fitted VX XE for almost same money.
If people say the engine you want has too much power - then dont put your foot down as far. Wind the throttle cable back a bit etc. Power will be useful one day.
jpindy3
posted on 18/9/09 at 08:10 PM Reply With Quote
go for the t5,turbo kitcars are so much fun,plus you can run rings around most things on the road.
NS Dev
posted on 18/9/09 at 10:10 PM Reply With Quote
correct
NS Dev
posted on 18/9/09 at 10:17 PM Reply With Quote
PS power is one thing, power delivery quite another!!
That Opel Kadett I keep rattling on about on here constantly reminds me of this fact!!
its 400hp, in 750kg, fine, nowt earth shattering, but the problem is it goes from 150hp to 350hp in about a 500rpm jump, or so it feels, and as soon as the power comes on, it spins up, in any gear, on any surface.
on a glued track at santa pod it found something else to spin and burnt the 6 paddle, cerametallic, 300% uprated clutch to bits............
Turbos have to be used with knowledge, particularly that when you are in the mood, they are great fun, but when the non-turbo car in front keeps getting away from you, it can be a right bugger to hang on!
I have 200hp non-turbo in the form of vauxhall XE, and around 540kg weight wise. I think in that sort of weight, 250hp would be nice, 200 is not quite enough, though obviously still ridiculously quick, 0-60 under 4 secs etc, just that mid range acceleration could be a bit better with a bit more torque and more top end power.
clear as mud!
<<  1    2  >>
