Gergely
posted on 29/10/09 at 08:19 AM |
5VY R1 Charcoal Canister pipes???
Hi, I have two pipes that come from No. 1 and 4 throttle bodies, are linked with a T piece and originally - looking at various pictures in the service
manual - were connected to a charcoal canister to avoid fuel vapour entering the atmosphere. Apparently this is only done for California models. I
know that our original engine was an american one, so it might be a Californian one.
My question is: What should I do with these pipes? Simply connect the two without the T piece and that's it?
Currently I fitted a simple, cheap plastic filter on the T piece, but i am afraid that it sucks in some air there which might upset the fuel/air
ratio.
(The Power Commander is not set up yet, I am going on a rolling road soon, but obviously would want the pipes to be in their final state when on the
rolling road to make sure that the Power Commander is set up correctly).
So, just connecvt the two hoses together? Or plug them? Or keep the small fuel filter?
Thanks for any info!
Gergely
Our build pictures
adithorp
posted on 29/10/09 at 08:25 AM |
Blank them off.
Charcoal canisters are normally controled by a solenoid, so that they only draw the gasses from the canister into the throttles under circumstances
when it won't affect the engine. Without the canister and control you don't want any air entering there. It'll just make those 2
cylinders run (very) weak.
http://jpsc.org.uk/forum/
Gergely
posted on 29/10/09 at 04:02 PM |
Thanks! Your response confirms what I thought, too. Great help!
Gergely
Our build pictures
