Author: Subject: 306 hdi brake problem
macspeedy
posted on 16/12/09 at 08:51 PM Reply With Quote
well started the other day towing a trailer after about 100 mile light for handbrake on came on.
After checkin brake fluid level and pulling handbrake on and off it stayed on
The next day when going to drive the light wasnt on at first but appeared after 10-20 mins driving.. brakes seem fine not pulling and have 8-9 mm of pad left all round.
Has been coming on and off like that for a few days now.
Any suggestions welcome
Mac
big_wasa
posted on 16/12/09 at 08:53 PM Reply With Quote
bad earth or loose wire on hand brake switch would be my guess.
posted on 16/12/09 at 08:55 PM Reply With Quote
The brake warning light isn't shared with the ABS ?
will121
posted on 16/12/09 at 09:03 PM Reply With Quote
ive got a 306 Hdi sound just like dodgy switch making, could be something silly like have you kept a pen or pennys in the tray where the hand brake is which may have slipped down the back so the handbrake wont go right down? check that then switch.
by the way what do you tow, small trailer or car? as ive been looking at a car trailer as Hdi ment to have a max tow weight of 1350kg
[Edited on 16/12/09 by will121]
DRC INDY 7
posted on 16/12/09 at 09:08 PM Reply With Quote
Nobody said it did where did that come from ?
Puddle Dodgers Club
macspeedy
posted on 16/12/09 at 09:10 PM Reply With Quote
abs has its own light
towing bec on caravan single axle trailer.. tows well..
will check those out thanks
[Edited on 16/12/09 by macspeedy]
Michael
posted on 16/12/09 at 09:34 PM Reply With Quote
I know its a 306 your refering two, but 406 did suffer from handbrake switch playing up.
[Edited on 16/12/09 by Michael]
adithorp
posted on 16/12/09 at 10:13 PM Reply With Quote
See that little squigly line with a dot under it after ABS. That means it's a question.
http://jpsc.org.uk/forum/
DRC INDY 7
posted on 16/12/09 at 10:41 PM Reply With Quote
Silly me trouble is i assumed britishtrident knew what he was talking about now i see that is not the case
Puddle Dodgers Club
posted on 17/12/09 at 12:41 PM Reply With Quote
Handbrake switch would be my first check, followed by a check on the contacts/switch in the fluid resevoir.
SWMBOs 306 HDI has just decided the rear wash/wipe doesn't want to work which I'm betting will be a bad connection somewhere.
I still rate the 306 as a very good car all round, but French electrics leave a little to be desired.
will121
posted on 17/12/09 at 01:00 PM Reply With Quote
there is a relay behind the plastic cover in the boot lid just below the rear wiper arm prone to water ingress though the wiper spigot seal which corrodes contacts,
posted on 18/12/09 at 09:31 PM Reply With Quote
Spot on! I'll start my investigation there then
ChrisW
posted on 19/12/09 at 01:43 PM Reply With Quote
The handbrake switch got stuck on my 306 (phase 1 Cabrio). Bit of WD sorted it.
And I agree with whoever said the 306 was a good car. The mid-90's Pugs certainly had the styling sorted out (they've gone wierd now tho) and the 306 Cabriolet and 406 coupe especially look great with a few subtle tweaks. Just a shame about the build quality, and as has been pointed out, the electrics. The hard top 306's handle well too if they're not too tired.
My Cabriolet: http://www.chrisw.net/photos/?dir=My%20306%20Cabriolet
Chris
