Author: Subject: 2001 Astra wishbone replacement
r1_pete
posted on 18/12/09 at 03:15 PM Reply With Quote
Further to my last post wanting a wishbone, I've now got one, suprised really only £20 new.
A question about fitting, is the bottom of the suspension leg a pinch bolt arrangement onto the ball joint? also any other fitting quirks, it does look fairly straightforward.....
adithorp
posted on 18/12/09 at 04:20 PM Reply With Quote
Bottom ball joint is a pinch bolt. Knock a thin chisel in to loosen it.
The back bush has 2 thin tin dowels up the hole to locate it. Bit of a pain to align and if it's been changed before don't be surprised if they're missing. New 'bone should come with replacement ones unless it's a really cheap one.
adrian
http://jpsc.org.uk/forum/
