Author: Subject: 2002 Diesel Bora Problem
liam.mccaffrey
posted on 31/12/09 at 09:02 PM Reply With Quote
Got a problem with a Bora, anyone have any insight?
If you go over about 80 it loses all power then and afterards, as if turbo is off boost all the time. Everything seems to return to normal if you turn off the ignition and restart.
Looked at the live data from the OBD2 and noticed that the value from the MAP sensor never changes at 72.2 in/Hg. Also when the loss occurs the %load value drops to 0%
MAF sensor looks normal and output varies with rpm from about 1.5 to 7 lbs/min
Any thoughts?? i'm thinking MAP sensor.
Build Blog
Build Photo Album
franky
posted on 31/12/09 at 09:31 PM Reply With Quote
if its not the maf it's the actuator arm on the turbo sticking causing overboost(i've had it before), some places will say a new turbo but you can have yours fixed, its a curved arm that wears down with friction.
gregs
posted on 1/1/10 at 01:26 AM Reply With Quote
VNT or dump valve?
clanger
posted on 1/1/10 at 10:28 AM Reply With Quote
Check the small valve (name escapes me?) just after the boost delivery hose just as it enters the inlet maifold, right at the back near the bulhead as your looking into the engine bay. Its some sort of vaccum operated valve (fed off that ball reseviour at the front of the engine) which prevents the rattling when you switch off the engine. Mine has stuck closed a few times as it gets gummed up with residue. Feels like the turbo's fallen off when it jams
[Edited on 1/1/10 by clanger]
clanger
posted on 1/1/10 at 10:29 AM Reply With Quote
Originally posted by clanger
Check the small valve (name escapes me?) just after the boost delivery hose just as it enters the inlet maifold, right at the back near the bulkhead as your looking into the engine bay. Its some sort of vaccum operated valve (fed off that ball reseviour at the front of the engine) which prevents the diesel rattle noise when you switch off the engine. Mine has stuck closed a few times as it gets gummed up with residue. Feels like the turbo's fallen off when it jams
gregs
posted on 1/1/10 at 10:46 AM Reply With Quote
re-reading your question without the aid of beer....
If the map is static, i guess the ems must be running the engine of maf readings - surprised it isn't flagging a fault - might be interesting to see what happens with the maf disconnected (it shouldn't run obviously).
I'd go with your original analysis and change the map sensor, at least rule it out...
liam.mccaffrey
posted on 1/1/10 at 04:59 PM Reply With Quote
good suggestions all, it doesn't show any faults.
will check a few of those things
Build Blog
Build Photo Album
