Author: Subject: 1998 Alfa 146 problem.
Andi
posted on 3/1/10 at 05:27 PM Reply With Quote
Just towed a mate back from Loughborough as his Alfa packed up when going along.
The cambelt isnt moving when cranking seems quite taught still. The other belts are working ok.
What else could be wrong?
Thanks in advance
Andi
DRC INDY 7
posted on 3/1/10 at 05:30 PM Reply With Quote
If the cambelt is not moveing when cranking
Teeth stripped on the belt
crank pulley bolt loose
crank pulley key way sheared etc
Puddle Dodgers Club
plentywahalla
posted on 3/1/10 at 05:36 PM Reply With Quote
Italian engineering !!
I'd bet on crank pulley key sheared. Fiats are famous for it ... must be something in the Italian steel
franky
posted on 3/1/10 at 06:06 PM Reply With Quote
Great engines but a full cambelt kit needs doing every 36k...... when was the last one?
Alfa145
posted on 3/1/10 at 07:13 PM Reply With Quote
Cambelt tensioner. Famous for not lasting much more than 36k. Also when the do go they eat valves and during this they munch the soft bottom end, so expect a large bill or just buy a new engine.
posted on 3/1/10 at 09:22 PM Reply With Quote
I'll go for the teeth on the belt stripped round the bottom pulley. It sounds expensive whatever it is.
Andi
posted on 3/1/10 at 09:47 PM Reply With Quote
Hmm! That what I was dreading.
Anyway thanks all for the replys, ill start having a mooch in the daylight.
