Author: Subject: citroen zx 1.9 td injector replacement tips
dlatch
posted on 16/1/10 at 10:27 AM Reply With Quote
got a new set of injectors for my ZX and gonna fit them this weekend if it stops raining.
anyone done these before? any tips on fitting?
cheers
duncan
posted on 16/1/10 at 02:04 PM Reply With Quote
Make sure you use the correct socket as I've seen a couple of of broken ones, normally the leak off pipe connectors. Replace the leak off pipes and cap even if they appear to be in good condition . DO NOT bend the injector pipes to get clearance, take them off if needed. Fit new sealing washers . Probably worth changing the fuel filter whilst your at it.
