t.j.
posted on 23/1/10 at 05:12 PM |
Any Audi-experts around?
My Audi A4 with 2.0litre ALT, running on LPG has problems......
I notice misfires only if I drive. Around 1800 rpm and while accelerating and dec.
Code: P0300 and P0304 So, right misfires and misfire on cylinder 4.
Next:
P1479 vacuum-brake; checked the hoses; ordered 2 new ones, cause they are weakened by oil, they collapes by the vacuum. But no leaks.
P0420 Catalysator converter working poor.
So. any one good (and cheap) idea's?
matt_gsxr
posted on 23/1/10 at 05:14 PM |
Does this model have the dodgy coil on plug problem that the audi's had?
Matt
omega 24 v6
posted on 23/1/10 at 05:21 PM |
Catalytic conbertor fault COULD be linked to the misfire (02 reading will be rich) due to unburnt fuel.
t.j.
posted on 23/1/10 at 05:23 PM |
Matt
Yep, already 4 new ones.. (80.000 km) a while ago.
t.j.
posted on 23/1/10 at 05:26 PM |
The exhaust test are fine..
But it stinks more...
Should I worry about my valves (300.000 kms) due the LPG?
posted on 23/1/10 at 05:56 PM |
Matt
+ 1
That would have been my guess - happened twice on Audi's I've had.
It's Evolution Baby!
TGR-ECOSSE
posted on 23/1/10 at 06:02 PM |
Another problem i've seen recently on vag engines with the single coils is cracked ceramic on the spark plug causing a missfire which shows up
as coil on the diagnostic check. I,m sure there was a note in the last new coil we got to say that there was a fault with some of them so worth
swapping the coils round to see if the fault stays on the same cylinder.
posted on 23/1/10 at 06:17 PM |
LPG will cause the valves to burn out , it needs harder seats and valves than unleaded . Did you fit new plugs when the coils were fitted?
t.j.
posted on 23/1/10 at 06:22 PM |
Yes the new plugs are only 2000 kms gone.
So it must be in the combustion or ignition/timing, because misfires also around in petrol-mode (only less)
