posted on 29/1/10 at 08:43 PM |
Fiat Stilo JTD problem
Anyone have any suggestions as to what could be causing a "loose connections" warning light to come on on a Fiat Stilo JTD , engine cuts
out as if the ignition was switched off and will not start again. Starter will crank the engine over but it will not fire , have been cleaning
terminals but as yet haven't found the cause.
mookaloid
posted on 29/1/10 at 08:47 PM |
Is that the engine management warning light to which you refer?
Dodgy ignition switch?
theconrodkid
posted on 29/1/10 at 09:26 PM |
have a look at the fuse box under the dash,they normally fill up with water,i found them nearly impossible to save but they were pretty cheap
who cares who wins
pass the pork pies
posted on 30/1/10 at 09:09 AM |
Cheers John will look on Monday
Mark Allanson
posted on 30/1/10 at 09:18 AM |
I know! I know!I know! I know!I know! I know!I know! I know!I know! I know!I know! I know!!!!!!!!
I have just done one at work, same symptoms exactly. It was the crank position sensor just abouve the starter motor, one M6 bolt holding it in, cost
£32.50 from a factor
posted on 1/2/10 at 08:20 PM |
You do know , thanks for the tip Mark . Fitted one today and it fired up first touch of the key.
Mark Allanson
posted on 3/2/10 at 09:31 PM |
I love it when a plan comes together!
