Author: Subject: Will my disks be warped?
speedyxjs
posted on 30/1/10 at 04:14 PM Reply With Quote
After my caliper seized a few weeks ago and me having no money to sort it, i should eb able to get it sorted tomorrow but i was told the other day to expect the disk to be warped.
How likely is this? The car was driven about half a mile at 30 - 40 mph with the caliper seized (A27 is a sod to find somewhere safe to stop )
[Edited on 30-1-10 by speedyxjs]
mookaloid
posted on 30/1/10 at 04:16 PM Reply With Quote
it might or might not. you won't know for certain until you check it.
will121
posted on 30/1/10 at 04:19 PM Reply With Quote
possible if got that hot, no real way of telling till un-seized and you can spin it freely, or get the pads out and spin the disc
locoboy
Even if it is, so long as it is not nearing its minimum wear limit you can get them faced by a local engineering shop.
Locoboy
speedyxjs
posted on 30/1/10 at 04:57 PM Reply With Quote
^^^ didnt know that
cheers guys
Danozeman
posted on 30/1/10 at 05:34 PM Reply With Quote
Il stick my neck out and say it wont be unless you braked hard while it was hot.
Dan
blakep82
posted on 30/1/10 at 06:43 PM Reply With Quote
does the steering shake when you brake?
half a mile, i wouldn't have thought it would be too bad
________________________
speedyxjs
posted on 30/1/10 at 08:42 PM Reply With Quote
Havent changed it yet. Thought id check as if everyone said 'of course they will have warped', i would change the disks while i am there.
jeffw
posted on 30/1/10 at 09:06 PM Reply With Quote
Discs do not tend to "warp" as such. Normally what people think of as warping is pad deposits or where the structure of the metal itself changes due to extreme heat.
Often 'warped' discs can be cleaned up by some hard stops over a short period as this will get the disc up to a decent temp and clean them up. Failing that you can get them faced.
More info here
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
gazza285
posted on 30/1/10 at 11:53 PM Reply With Quote
25 years ago it was economical to get warped disks skimmed, but I doubt the same is true now.
