AndyGT
posted on 30/1/10 at 08:00 PM |
rear brakes
Hi All! I am doing some work on an old nova and there are three sizes of wheel cylinders for replacement. The ones fitted are 14mm but there are
some others available at 17mm and 18.x mm. I was under the impression that if I fitted bigger cylinders it would reduce the pressure to rear and more
at the front as it requires more displacement. But I have seen a website that states the opposite.
So my question: Does fitting bigger bore cylinders on rear increase or decrease rear brake efficiency according to pedal displacement? How will this
effect overall brake performance on the car?
Thanks in advance.
nothing is impossible
everything is possible
mistergrumpy
posted on 30/1/10 at 08:03 PM |
I always thought smaller bores = higher pressures. That's the way it works on master cylinders.
adithorp
posted on 30/1/10 at 08:08 PM |
Bigger slave cylinders increase the braking. Smaller master cylinders increase the braking.
adrian
http://jpsc.org.uk/forum/
RAYLEE29
posted on 30/1/10 at 08:24 PM |
As adrian says
Ray
alistairolsen
posted on 30/1/10 at 10:35 PM |
Line pressure is created by the master cylinder. When changing the slave cylinders, the larger the diameter, the greater the area. Since the force
exerted on the pads/shoes is pressure x area you get a greater breaking force to the rear.
My Build Thread
andrew-theasby
posted on 31/1/10 at 08:53 AM |
your rear braking will increase but you'll get more pedal travel
