vinny1275
posted on 1/2/10 at 10:50 AM |
Tin top tyre problem
Morning all,
Just had E-tyres out to fit new tyres to swmbo's E39 5 Series. Unfortunately, whoever fitted the last set of rears overtorqued the bolts
(they're supposed to be 120 Nm, his Torque wrench at 200 was clicking off), so he had to use the breaker bar on them. Unfortunately, when he got
to the locking wheel nut, it rounded the splines on the key....
so, the question: Once I've got a new key from BMW, how do I get the bolt out without rounding the new one as well?
Vince
55ant
posted on 1/2/10 at 11:08 AM |
there is a proper way to do it im sure, but i have had good resulty getting a ratchet head, maybe 15mm? then hammer it into the lockable wheel nut,
the use a big breaker bar, or, take it to an enginnering company and have them take it out, dont forget to take another to replace it with for the
drive home.
away from cars, now cycling and building TT bikes
vinny1275
posted on 1/2/10 at 11:11 AM |
It's one of the ones where the splines are on the inside of a socket cap head, so I don't think a hex socket would go around it. Oxy torch
maybe?
dhutch
posted on 1/2/10 at 11:28 AM |
quote: Originally posted by vinny1275 Oxy torch maybe?
Could well be.
- Get a good welder to weld a nut onto it?
Just dont go down the angle grinder to the wheel root unless you have to (ref to past thread)
Daniel
karlak
posted on 1/2/10 at 11:31 AM |
Some tyre depots have a "tool for the job" - Worth ringing a couple up and see what they say.
Guess they have something like this --- http://www.lockingwheelnutremover.co.uk/indexEnglish.html
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
vinny1275
posted on 1/2/10 at 02:41 PM |
Thanks all,
had to go to BMW to get a replacement key and some bolts anyway, so I've booked it in for them to sort...
vince
