RIL2002
posted on 12/2/10 at 05:38 PM |
fireblade breaking clutch cables
Hi Folks,
I have a mk indy blade and although I have uprated the cable it still breaks at either end just where the lugs are.
The cable comes away from the soldered lug and iam begging to wonder if the clutch is faulty as it seems very heavy and I cant move the clutch lever
by hand.
Idont know if the clutch has been uprated or not
Cable is free to move and running in line with everything. Its the standard mk clutch pedel with the slot at the side for the cabel, lug to go
into.
Any Ideas?
mistergrumpy
posted on 12/2/10 at 05:46 PM |
Where the cable is in the soldered nipple, have you frayed the ends of it out before pouring in the solder?
The clutch arm is all but impossible to move by hand so I wouldn't worry about it.
RIL2002
posted on 12/2/10 at 06:32 PM |
Thanks for the reply,
Yea I have frayed the end but will resolder again and try once more.
Anybody know if anyone can make me a clutch bracket with adjuster for my clutch cable as the one i have, has not got any adjuster or adjustment
The engine is a 1997 919 blade.
austin man
posted on 12/2/10 at 08:34 PM |
is the cable able to move ?? is it breaking at the pedal end if so it could be that the cable is not being allowed to swivel therefore bending
causing stress. We had this problem on a zetec engined car
gordon h
posted on 12/2/10 at 08:46 PM |
use a seirra 4x4 clutch cable they do 2 u need the longest 1, cable is lined and makes the pedal easy to push even by hand.
bec is best but going to try sabb 2.3 turbo mk
Mark G
posted on 12/2/10 at 09:10 PM |
Mine snapped after only about 600 miles. Not ideal really. Fortunately I was only a mile away from home at the time.
RIL2002
posted on 13/2/10 at 03:16 PM |
Thanks again guys for the replys,
Where the cable goes through the bulkhead there is a hole with a 17mm bolt and nut through it with a 4.5mm hole bored through the centre where the
inner cable goes through to the pedal.
I was wondering if i took this out and used a washer with a hole in the middle would this give me a better angle to the pedel?
Once again if anybody knows where I can buy or who makes a clutch adjuster plate for my 97, 919 blade engine I would be much obliged.
