Author: Subject: OT electronic circuitry experts
alistairolsen
posted on 19/2/10 at 09:35 PM Reply With Quote
If I need to have non linear boost control on a severe budget (i.e a bleed valve or MBC wont work) can someone give me some advice on possible circuitry?
It would need to read the rpm signal(pulse), and the throttle position sensor(potentiometer, and drive a Boost solenoid (commonly PWM)
Id want to have something like linear relationship between boost and throttle opening, but limited to 2 psi at 3kprm, 4psi at 4k, 6psi at 5k and 8 psi at 6k or thereabouts.
I know you can buy them for a couple of hundred quid and they are nicely mappable, but Im looking for a locost way to achieve the above effect. Im not afraid of soldering, nor is the engine particularly expensive.
Any advice?
Cheers!
My Build Thread
tegwin
posted on 19/2/10 at 10:16 PM Reply With Quote
If I were doing it I would build it around a PICaxe chip... Write the progtam yourself using a flow chart style programmer..
Just make sure that it will fail safe.... IE have a sepperate system that shuts the engine off if boost gets too high by accident if the pic fails...
The datasheets for the PICaxe chips explain how the outputs/inputs work and how to wire them up...
Could take the analogue inputs and then, quite easily drive a PWM system via a transistor/triac
www.verticalhorizonsmedia.tv
posted on 19/2/10 at 10:39 PM Reply With Quote
Jaycar make a boost controller kit for ~£23.
alistairolsen
posted on 19/2/10 at 10:44 PM Reply With Quote
that looks just the ticket. Shame its not laptop programmable instead of a separate £20 kit. Showing as out of stock though
My Build Thread
turbodisplay
posted on 20/2/10 at 07:44 AM Reply With Quote
A boost controller can only make higher boost than what the wastegate is set at.
Normally 5 -7 psi (part throttle restriction helps to reduce this).
Saab have an apc unit that is quite advanced, adjustable internally.
Cheapest good way is a processor like a pic processsor.
I would recommend the 18f series as theyare faily logical, with no need for banking for the first 256 bytes of ram.
Darren
alistairolsen
posted on 20/2/10 at 09:42 AM Reply With Quote
yeah I understand the wategate issue and Im hoping to test exactly what it can take at some point.
Whats the story with the saab unit? Is it external to the ecu? How do you adjust it? What cars was it fitted to?
is the pic processor you mention above the same as the PICaxe one mentioned earlier? How do you mean fairly logical? Im an electronics retard but as far as I knew all chips are logical by definition?
Cheers everyone!
My Build Thread
alistairolsen
posted on 23/2/10 at 10:55 AM Reply With Quote
Ive done a wee bit of reading on the APC system and it looks like a good system and fairly easy to transplant into another car. From what I can see of the internal mods you can raise the boost pressure it ultimately allows, but at the same time the lower limit is also raised (fixed range).
Has anyone on here got any experience with it? It certainly looks tempting if I can find a scrap man who doesnt know what it is!
Cheers!
My Build Thread
