<<  1    2  >>
Author: Subject: Lotus Twin-Cam Engine
posted on 25/2/10 at 09:34 AM Reply With Quote
Good morning enlightened one's!
Anyone know the weight of the good ol' Lotus Twincam engine???
It's Evolution Baby!
cd.thomson
posted on 25/2/10 at 09:37 AM Reply With Quote
0.13 average sized african elephants.
Craig
r1_pete
posted on 25/2/10 at 09:49 AM Reply With Quote
About the same as a crossflow, if its the Ford pre crossflow derrived unit.
and the next question, what does a crossflow weigh?
Sorry probably a less than usefull response....
[Edited on 25/2/10 by r1_pete]
posted on 25/2/10 at 09:52 AM Reply With Quote
Every little helps!
The elephant indication gives me a rough idea!
t16turbotone
from my list it says -
Lotus 907 275 lbs inc. alt. & starter, no clutch
posted on 25/2/10 at 10:00 AM Reply With Quote
Sorry - meant the 1558cc one.
posted on 25/2/10 at 10:02 AM Reply With Quote
Blinkin flip... 26 minutes and no definitive answer - this place is going to the dogs I tell you!!!
t16turbotone
posted on 25/2/10 at 10:05 AM Reply With Quote
only have ford kent engine listed at 260lbs
MikeR
posted on 25/2/10 at 10:10 AM Reply With Quote
about 80kg's
(guess based on my approximate memory of what a crossflow weighs)
if you think this is a poor response, i had to reply to my own question a week after i'd asked it the other month!!!!
mcerd1
posted on 25/2/10 at 10:17 AM Reply With Quote
why you want to know ? / what are you up to now ?
balidey
posted on 25/2/10 at 10:22 AM Reply With Quote
E-Type with a twinky engine?
Those drugs are not kind to you are they
alistairolsen
A vauxhall C20xe is 155kg and a 1.2 8v is 130 ish.
bearing in mind the twink is a similar size to the 1.2 block, but with a larger head and an extra cam, Id estimate 135-140kg.
My Build Thread
MikeR
posted on 25/2/10 at 10:29 AM Reply With Quote
how heavy???
bloke shipping engine minus the head is weighed in at 60kg, so my guess at 20kg for the head may be pretty close.
(and with the link this time)
http://www.shiply.com/transport/Lotus-Twin-Cam-Engine-Escort-Cortina-Rally-L-Block-Elan/140997/
[Edited on 25/2/10 by MikeR]
posted on 25/2/10 at 10:35 AM Reply With Quote
Cheers guys...
posted on 25/2/10 at 10:42 AM Reply With Quote
Just mulling over my next steps... need to make a solid decision as to whether I should flog all the kit bits, engines, etc. and buy an interesting 'sunday' car?
Thinking:
Late Jaguar XJS (6.0 V12), or
Lotus Elan or Europa
alistairolsen
posted on 25/2/10 at 10:43 AM Reply With Quote
Originally posted by MikeR
how heavy???
plus cams, pumps, pulleys, crank, flywheel rods, pistons..........
My Build Thread
alistairolsen
posted on 25/2/10 at 10:44 AM Reply With Quote
Thinking:
if you do, then at least get one of the new spyder chassis and build one with a xetec in it. Please do not think youll buy a lotus twink and use it relaibly on the road for any reasonable cost!
My Build Thread
posted on 25/2/10 at 10:56 AM Reply With Quote
Yep... but would put a Duratec in it - hence the reason I asked about weight - was curious to see how they compare!
posted on 25/2/10 at 11:17 AM Reply With Quote
1558 Twincam was a money pit when it was new running one now would be more like a money black hole.
MikeR
posted on 25/2/10 at 11:18 AM Reply With Quote
how heavy???
The engine pictured appears to have crank, pistons & rods in it so its just the head and fly thats missing. I wouldn't quote a flywheel weight in an engine weight so we're back to my original comment, its the head thats missing.
alistairolsen
posted on 25/2/10 at 11:21 AM Reply With Quote
Fair enough, the weights I quoted included the flywheel, clutch cover, both manifolds loom and ecu as I wanted a direct before/after comparison. You can probably knock 25+kg off both if youre not including any of that.
My Build Thread
posted on 25/2/10 at 11:35 AM Reply With Quote
All the very very expensive bits are missing --- really take a deep breath and swallow some sensible pills.
These engines need constant attention and when engine work is needed they are not DIY friendly they need fettled by an engine builder specialist in these engines.
907
posted on 25/2/10 at 11:53 AM Reply With Quote
Nah!
Can't be that heavy.
I lifted it in with one hand and did up the bolts with the other.
Paul G
posted on 25/2/10 at 12:05 PM Reply With Quote
Thanks guys!
The car I'm looking has just been restored... the engine and gearbox are still out, so if I bought it, I'd be moving the Twincam engine and box along (selling stuff... what, who me???).
Seem to fetch pretty good money!
mcerd1
posted on 25/2/10 at 12:10 PM Reply With Quote
so does that mean you'll be looking for pinto to go in the quantum then
<<  1    2  >>
