zilspeed
posted on 13/3/10 at 01:59 PM |
B100 Biodiesel at the pump
Been running on it for around a month now.
Didn't want to fess up before now in case it all went a bit Pete Tong.
Rather conveniently, there are two place quite near me who both sell it at the pump.
One of them I haven't visited yet, because he's a bit dear.
89p a litre.
The other one which is a bit nearer me gets my vote. He doesn't advertise and is a bit tricky to find. Also, if you go too late in the day,
he's sold out. His pump seems to be broken, because the money bit of the display seems to take so long to go up.
85p a litre.
Anyone else tried this brave new tree hugging world reprocessed transesterification pakora / chip / doughnut oil goodness ?
PS - the engine in the Zilbus is an HDI, so wouldn't run on stuff that isn't 100% ok.
Predictably, the less enlightened of my workmates won't even try it. They much prefer the 114p a litre supermarket stuff.
sebastiaan
posted on 13/3/10 at 02:31 PM |
Biggest bonus: it doesn't make you smell like sh*t if you get it on your hands!
carlknight1982
posted on 13/3/10 at 02:34 PM |
i did some trials with B100 from a company called bionic fuels on generators and on an engine sitting at constant RPM it causes significant damage,
you get deposits form on the injector nozzles which in turn stops proper atomisation causing fuel to run down the bores and gather in the sump, this
dilutes the enigne oil to the point of causing excessive wear in the big ends, then a chemical reacion takes place between the b100/oil and white
metal in the sump causing the oil to turn to something akin to Tar.
however on the plus side we did a rpm range test on 2 vans and never had an issue, it seems the 1500rpm speed of a diesel generator was the main area
of concern.
Logic will get you from a A to B
Imagination will take you everywhere.
prawnabie
posted on 13/3/10 at 02:46 PM |
We have had 4 cans at work now that have needed complete fuel systems on - all 4 owners have admitted running them on biodiesel!!
Each one had a fuel filter full of sludge and a pump that couldn't delver the fuel pressure required...
sebastiaan
posted on 13/3/10 at 02:48 PM |
Are you sure you are not mixing up biodiesel and PPO?
zilspeed
posted on 13/3/10 at 03:02 PM |
The sludge thing I can understand.
I went into this completely expecting to have to have to fit a new fuel filter quite early on. I'm told it cleans out the fuel system and
deposits all the crud in the fuel filter. Thereafter, it should be no more than normal servicing.
I certainly wouldn't run it on SVO, it just wouldn't run at all being an HDI rather than an old fashioned straightforward mechanical
system.
posted on 13/3/10 at 04:03 PM |
I used to buy the 3 litre bottles of rape oil in Tesco and tip them straight into the tank in the car park.
Never had an issue, just stopped using it cause its the same price as derv atm
NigeEss
posted on 13/3/10 at 09:18 PM |
Ditto but the 20l drums from Costco.
Ninehigh
posted on 14/3/10 at 12:44 AM |
There's also something about the fuel pump. The type that is lubricated from the diesel (like in my Mondeo) doesn't like bio one bit.
After filling up on it twice I could barely get to 30mph with a full load of people without it cutting out on me. Shame really as I could get it for
70p/l when normal diesel was £1.30.
Ford recommends no more than 5% bio, but I have seen old mercs and land rovers running off oil fresh filtered from the chippy
MikeR
posted on 14/3/10 at 09:21 AM |
few things here...
bio cleans out the fuel system. Normal diesel has lots of crap in it. If you change over then replace the fuel filter and after 500 miles replace it
again. From then on, if you stick to bio you can stick to normal service interval.
If you're getting straight 100bio and not making your own - be careful. Get the testing equipments from a place that sells the stuff for you to
make your own and test the fuel you buy. Lad round here did it and found the local 85p / litre supplier was not doing a proper job leaving too much of
a chemical in the fuel. This would over time wreck your fuel system.
Also, check what pump you have. On the older mechanical pumps like on landrovers the bosch pump works on the stuff fine. The lucas dies quickly. On
more modern HDI stuff .... it seems its up to you. Some manufacturers say its ok, others say max 5%. I've no idea how much this is down to deals
with fuel companies and how much is fact - what i do know is modern fuel pumps cost a fortune.
so in summary - if your pump can take it and you're getting decent fuel, you'll be fine. If you've got poor fuel / the pump
can't take it / you don't clean the fuel filter out it will have problems.
(experience from reading up on this a LOT and having a bloke in the office who makes his own in large quantities).
zilspeed
posted on 14/3/10 at 12:06 PM |
Mike
You're quite right.
Apart from the gelling in the cold, the cautious side of me tells me to run a mix at all times - to lessen any such effects.
I do get what you're saying about doing your own testing and have been reading a lot on the subject.
Ninehigh
posted on 14/3/10 at 03:18 PM |
That's the one, lubricated by the diesel and bio's too thin to work properly
