001Ben
posted on 5/4/10 at 12:20 PM |
Trolley jack
Does anyone know where i can buy 2 fairly cheap high lift trolley jacks, they need to go from 95 up to 450 high
Paul TigerB6
posted on 5/4/10 at 12:32 PM |
Trolley jacks rather than bottle jacks for that particular job Ben??
001Ben
posted on 5/4/10 at 12:34 PM |
Bottle jacks could work if you could find one small enough..
[Edited on 5/4/10 by 001Ben]
Paul TigerB6
posted on 5/4/10 at 12:36 PM |
link
So whats the minimum height you need mate??
Edit: duh - 95mm!!
[Edited on 5/4/10 by Paul TigerB6]
001Ben
posted on 5/4/10 at 01:26 PM |
I need one for each of the platforms when its on the ground so that I can lift the car to put the end plates on - save using the current seup as you
can see.
Ramp
T66
posted on 5/4/10 at 03:58 PM |
No good if your not am member
Costco are selling a 3tonne unit, very low profile which will suit your needs.
From memory they are about 60gbp
001Ben
posted on 5/4/10 at 04:12 PM |
cheers, i will go and take a look tomorrow
001Ben
posted on 5/4/10 at 04:21 PM |
costco
T66
posted on 5/4/10 at 06:21 PM |
Your jacking higher than a lot of garage jacks would stretch to, the 10tonne truck jacks I used to use wouldnt lift as high as your after.
It lifts to 21 inches...according to this forum but the UK one I have is red but looks more or less the same.
This is similar to it..
http://www.bimmerfest.com/forums/showthread.php?t=80476
iank
posted on 5/4/10 at 07:05 PM |
The large range is the biggest problem for a bottle jack.
Distinctly not cheap, and is about 2" too tall at lowest point for the spec, but this one does 125mm-800mm.
http://www.machinemart.co.uk/shop/product/details/ctj2glc-2-tonne-hd-high-lift-trolley-ja
Anonymous
001Ben
posted on 5/4/10 at 10:15 PM |
800mm thats insane for a car lift.
Thanks for the replies
MikeLR
posted on 6/4/10 at 09:10 AM |
Have a look in Halfords, they are having a big sale at the moment and had lots of shop soiled stuff on sale locally yesterday.
iank
posted on 6/4/10 at 09:42 AM |
It's designed for 4x4's where a regular jack won't even get the wheels off the ground, though at 2 tonne's it's a bit
lightweight for a land/range rover.
Anonymous
001Ben
posted on 6/4/10 at 07:55 PM |
still looking for a jack, the maximum width is 290.
