will121
| posted on 11/4/10 at 03:34 PM |
recommend me a large ish diesel £2-£3k
my Peogeot 306 diesel has now done 220k miles and due for a change. Im looking for a replacement Diesel (40mpg+) possible estate for about £2-£3k
reasonable size as want to tow a car trailer minimum braked trailer 1300kg.
Ideas so far;
Mondeo
Laguna
vectra
even a volvo V70
any more, or recomendations?
ive been looking at auctions can get a 02 100-120k miles in this price range
franky
| posted on 11/4/10 at 03:36 PM |
passat tdi.
wilkingj
| posted on 11/4/10 at 04:00 PM |
I have a Volvo 850 Petrol, I just wish it was a diesel. Bloody Excellent motor, except the 26mpg on petrol.
My mate gets 55 on a run and 47 locally on his Volvo diesel S60. Its chipped and goes like the wind, and does excellent mpg.
That one has the D5 Diesel engine... nice engine.
Downside is thay are expensive even when they are gettign on in age.
Just my 2d's worth.
Best Regards
Geoff
http://www.v8viento.co.uk
StevieB
| posted on 11/4/10 at 04:08 PM |
I have an S60 D5. Awesome engine - 180bhp and stacks of torque.
I've had it for 4 years and never really missed a beat - it's had a bit of work recently but I put it down to 130,000 miles and
they've all been wear and tear items (suspension bushes, starter motor etc.).
Should be able to pick one up in your price range and if it's an SE model will be suitably loaded spec wise (I have the standard S and it has
everything I would ever want as it is).
pewe
| posted on 11/4/10 at 04:23 PM |
SAAB 9-5 diesel - lots of goodies as standard and great value for money.
HTH.
Cheers, Pewe
Myke 2463
| posted on 11/4/10 at 04:31 PM |
Mondeo TDCI 130. over 98k no prob, tows 1800kg with ease. 45mpg towing 1200 kg.
SteveWalker
| posted on 11/4/10 at 04:47 PM |
I had a Nissan Primera 2.2 Diesel which I was very happy with. Only got rid of it as it had some warranty work done on it and the Nissan Dealer made a
right mess of it (they had it for two weeks instead of one and then it went back five times to put right things they'd messed up when they did
the work. Final straw was when I came to change the front brake pads a month later and found out they'd re-used the hub nut split pins, one of
which was broken and the other had fallen out completely At that point I felt I didn't know what else could be lurking and couldn't
trust the car again, so I traded it in for a Ford Focus 1.8TDCI).
thunderace
| posted on 11/4/10 at 05:18 PM |
a transit
cheep to run and loads of room .
edspurrier
| posted on 11/4/10 at 05:40 PM |
I've got an Accord diesel - 2006 2.2 - which is excellent generally, though it tows 1000kg odd of tiger and trailer with no problem the mpg does
drop to about 35 towing.
So I'm pondering a Skoda.
| posted on 11/4/10 at 06:18 PM |
Rover 75 CDTi Tourer towing capacity 1600kg braked
| posted on 11/4/10 at 06:30 PM |
And the Renault DCi Diesels carry major money pit warnings, turbos fails. at anything over 80,000 miles which is bad enough but it self destructs
and the debris tries to exit via the cylinders. ---- the causes is a lubrication problem Renault stretched the service interval and didn't
specify a fully synthetic oil. Usually EGR valve occur problems first and is sign that big trouble is on the way. Problem dosen't seem to
occur if fully synthetic oil has been used since new and/or oil has been changed every 5,000 miles.
This problem applies equally to Nissans with Renault Diesels. Much less of a problem on the little 1.5DCi than the bigger 1.9 and 2.1 engines.
| posted on 11/4/10 at 06:37 PM |
Problem with Ford TDCI is do just about anything on the engine and it has to be connected by the Ford dealer to the Ford factory computer to get the
part coded into the ECU.
Other thing to watch with Fords is dual mass flywheel problems which were common before 2003 after 2003 they must have quietly modified the part
because they don't give anything like as much trouble.
StevieB
| posted on 11/4/10 at 08:25 PM |
Yep - I've known of 2 that have gone exactly the same way.
