Author: Subject: Injector cleaner
roadrunner
posted on 21/4/10 at 06:21 PM Reply With Quote
Injector cleaner
Which is the best one for diesels, I'm not after a cheap one just one that will work well.
Brad.
dazzx10r
posted on 21/4/10 at 06:29 PM Reply With Quote
Forte diesel treatment or millers, used them both, the forte products are very good.
jacko
posted on 21/4/10 at 06:34 PM Reply With Quote
I use stp
How are you Brad ?
Graham
adithorp
posted on 21/4/10 at 07:09 PM Reply With Quote
Forts diesel fuel conditioner.
Best way to use it, is to fill a new fuel filter with it and start up so it runs on it neat, initially. It will work if you just add it to the tank but the results take longer.
I've had amazing results on diesels that I'd have previously though needed new injectors.
It's theoretically trade only but you can get it on the net. If you have trouble getting it, let me know and I'll bring some to Stoneleigh.
adrian
http://jpsc.org.uk/forum/
paulf
posted on 21/4/10 at 07:12 PM Reply With Quote
Ive always used one from the motor factors called Revite it comes in a small can with screw top , ive never seen it for sale other than in motor factors.
I drain the diesel filter and fill it with the cleaner then refit it and run the engine at 2000 revs for about 5 mins then take it for a good thrash on the road using low gears.Ive always found it to work to get cars through the MOT test after they have failed the smoke test.
Paul
