femster87
posted on 24/4/10 at 07:27 PM |
advice needed
noticed flooded footwell in passenger side this morning, its not been raining so checked expansion tank, empty with mayolike oil and water mix.
I was thinking heater matrix might be gone, and maybe head gasket,
any suggestions on what to check?
cheers
lotusmadandy
posted on 24/4/10 at 07:31 PM |
Mayo in the header tank would suggest a blown head gasket to me.
Thats the only way water and oil could mix,unless someone has poured water into the oil filler,or vise versa.
[Edited on 24/4/10 by lotusmadandy]
daviep
posted on 24/4/10 at 07:33 PM |
Thats the only way water could get into the oil,unless someone has poured water into the oil filler.
If you have an oil cooler, the kind which sandwich behind the filter then this could leak oil in to coolant.
Davie
lotusmadandy
posted on 24/4/10 at 07:35 PM |
Didnt consider that Davie
daviep
posted on 24/4/10 at 07:44 PM |
TBH head gasket sounds more likely, leaking cooler wouldn't explain why the bottle is empty (unless it burst)
Davie
femster87
posted on 24/4/10 at 08:37 PM |
thanks for the help
