bassett
posted on 26/4/10 at 06:23 PM |
BMW 3 Series issues advice
Hi, a friend of my dads is losing his sight and looking to get rid of his car. Its barely been used the last year and is apparently in good condition.
One issue he said is the door locks and the brakes. As he wants it shifted he asked we buy any car who would take it off him for £1,000. My dad thinks
surely its worth more than that and suggested i buy it, repair, tidy it up and sell on. Details are sketchy i know its slate grey, X plate, low miles
and a big petrol engine but obviously has the issues, parkers would still rate a poor one at £2,000-£2,500. Does anyone know suseptible/common fault
door locking components on the 3 series? and any other things to look out for as i can probably afford it and hopefully make a profit but dont want to
end up spending more than i can make.
posted on 26/4/10 at 07:10 PM |
On an X plate --- early E46 ? the model series overlapped
If the lock issue is one door that locks remotely but won't unlock remotely then that it is likely to be that the door latch assembly needs
replaced. Should be ok as DIY job -- but it involves almost fully stripping out the door.
Apart from the ABS and Electronic stability control system brake system is fairly simple 4 discs with floating calipers, handbrake is a drum
brke inside the rear discs.
Most common ABS faults on the early E46 is duff wheel sensors especially the rear. The ABS can suffer other faults on these. Grapevine said there
was a mod to the flex brake hoses on non DSC equipped cars to stop the steering wheel snatching slightly when the foot brake is applied.
Like any car ABS pump and ECU failures are not unknown but not that common either.
However rather than changing expensive ABS parts by guess work it would probably be better to budget 200 quid (such as the Autel EU702) for a
scanner or software + dongle that will read the system codes
[Edited on 26/4/10 by britishtrident]
Danozeman
posted on 26/4/10 at 07:39 PM |
for a grand id snap it up. Brakes could be anything. siezed on due to not being used?
Dan
bassett
posted on 26/4/10 at 09:56 PM |
Any ideas what they go for roughly as i wasnt entirely sure i trusted parkers. Just to add it is a E46 and a saloon so probably not something id hold
onto personally but it is in the right colour(grey) with hopefully the right engine and does have leather.
My dad has mentioned the chap talked to a dealer who said something about a central control unit in the dash and quoted £600 Is there anything like
this or are is it solely the modules on the door which im hoping would be like VAG units ive come across that always break.
Adam
posted on 27/4/10 at 07:23 AM |
Never heard of BCU problems on BMW
All cars these days a have a BCU (Body Control Unit) that controls the central, locking sun roof, wipers, lights, dash board and other systems and
interfaces them with the other ECUs on the car.
