Author: Subject: Tintop brakes
adam1985
posted on 3/5/10 at 03:15 PM Reply With Quote
Tintop brakes
I've got to change the rear pads on my tin top it's a 08 civic type r what's the correct way do I take the cap of the filler so there's no pressure then push the pistons back or do I just push themback
will they need bleeding after
and does anyone have any tips with these brakes or are they straight forward
cheers adam
Paul TigerB6
posted on 3/5/10 at 03:17 PM Reply With Quote
Many cars need the rear pistons winding back in (with the cap off) because of the handbrake mechanism.
adam1985
posted on 3/5/10 at 03:33 PM Reply With Quote
yeah ive come across them before that need screwing in just wasnt 100% sure on he cap but that answers that cheers adam
Ninehigh
posted on 3/5/10 at 04:57 PM Reply With Quote
Strictly speaking if you were to remove the cap (which would relieve pressure) you're then letting moisture in so you'd need to replace the brake fluid. Also you have to wind them for the handbrake. Further be careful the Mondeo has some sort of one way valve that you can pop inside out if you're not careful and apparently this ruins the lot.
prawnabie
posted on 3/5/10 at 04:59 PM Reply With Quote
Clamp and disconnect the brake hose first.
posted on 3/5/10 at 05:35 PM Reply With Quote
Why?? If you slacken the bleed nipple and connect a bleed bottle any excess fluid will flow out of the nipple when the piston is wound back which on some cars is the safest way of doing the job without collapsing the master cylinder (Astra's etc)
prawnabie
posted on 3/5/10 at 05:45 PM Reply With Quote
Sorry I meant slacken the nipple lol - I was thinking more along the lines of pushin fluid into the ABS unit with when I worked at TRW/Lucas was a big no no.
prawnabie
