daniel mason
posted on 6/5/10 at 05:33 PM |
engine in with pics and concerns!
managed to just about get the engine and box in last night and mounted! slight concerns over the height still remain as it is 11" higher then
the uppre chassis rail at the front and just over 12" higer at the back of the motor! the bonnet could need some serious mods but am not sure on
height of bonnet at moment as am not collecting bodywork until next week! is 12" very high or relatively
normal?
daniel mason
again
MkII
posted on 6/5/10 at 05:39 PM |
dont know the mnr that well but 11/12" sounds quite a lot of height, how much ground clearance have you got? .m.
skinned knuckles
posted on 6/5/10 at 05:41 PM |
looks a bit on the high side to me but i dont know the car.
A man isn't complete until he's married, then he's finished
daniel mason
posted on 6/5/10 at 05:42 PM |
its sat on the honda mounts and cant go any lower or gearbox would not fit!
ground clearence is better than my old R1 mnr
MkII
posted on 6/5/10 at 05:57 PM |
if mnr designed the chassis for your engine and all the mountings fit as they should then I guess it must be the correct height, just make sure you
fit some tall seats so you can see over it .m.
jacko
posted on 6/5/10 at 06:41 PM |
Will it be like this
![](/galpreviews/DSCN2711.JPG) ![How do you see [ blower ]](/gallery/DSCN2711.JPG) How do you see [ blower ]
![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif)
spdpug98
posted on 6/5/10 at 06:53 PM |
That looks 'Mahooooosive', I guess it all depends on how high your bonnet is and how high the top edge of the body is
My bonnet is approx 8.5" high on the front leading edge and about 9.5" just before the 'humps'
Good to see your build progressing
My Blog: http://spdpug98.wordpress.com/
SeanStone
posted on 6/5/10 at 06:58 PM |
I'm CNCing the S2000 dry sump that I've been designing tomorrow, from billet aluminium. If ground clearance is an issue, I might be able
to supply you with a billet pan. It's going to be 38mm deep, windage trays, scraper, 2 scavenge.
Guinness
posted on 6/5/10 at 07:04 PM |
I know the MNR bodywork is different to the Indy's, but from the top chassis rail to the highest point on the nosecone is about 9" and
from the top chassis rail to the scuttle is about 10". Do MNR do a bonnet with a bulge like the MK one?
daniel mason
posted on 6/5/10 at 08:22 PM |
dont think so^^
but am sure dax do a huge scoop as someone on here has one.cant remember who but its massive!
maximill666
posted on 6/5/10 at 08:28 PM |
quote: Originally posted by daniel mason
dont think so^^
Its 'iiyama' on here with the large scoop thats based on the dax one, but taller.
Linky
daniel mason
posted on 6/5/10 at 08:35 PM |
that is the same scoop but a different car to the one i saw! not sure who
Gergely
posted on 6/5/10 at 08:36 PM |
I suggest you check this build and talk to pwl. His engine fit under the standard bonnet (I think it's the same engine...).
Linky
Gergely
Our build pictures
daniel mason
posted on 6/5/10 at 08:43 PM |
been in contact with per. he gave me my exhaust! his looks a similar height as mine is about the same height as top scuttle bar!
sucksqueezebangblow
posted on 7/5/10 at 10:12 AM |
The MNR body work is taller than most if not all other 7 kits.
