vyperstrype
| posted on 8/5/10 at 11:09 AM |
MT75 Speedo Cable
Hi, just wondered if anybody has an old Speedo Cable lying around their Garage , that they no longer need.
The reason i ask is that i only need about 3" of the Gearbox end, as i run an electronic speedo. Basically, it needs to act as a seal on the
gearbox, so it doesn't matter about the inner cable being present, as i can just put some sealant down the outer cable.
Cheers Eric.
Where there's a will, there's a death!!
r1_pete
| posted on 8/5/10 at 12:16 PM |
The drive should be sealed, you don't need to put anything in there.
If its leaking you have a seal blown.
mgmiller
| posted on 8/5/10 at 01:14 PM |
run mine without a cable for a year with out any leaks
