norfolkluego
posted on 9/5/10 at 10:30 PM |
Redecking a trailer
My trailer needs a new deck, normally it lives in the garage with the Luego on it, but this winter while we were doing the engine swop we needed the
room so it lived outside. The cold weather has really damaged the plywood deck, the frosts have delaminated a lot of the ply, it's still usable
but it's going to need doing pretty soon. Exterior ply is horribly expensive and ally sheet is even worse in a suitable thickness. Any ideas of
the best way to go?
blakep82
posted on 9/5/10 at 10:40 PM |
anything like this any use?
http://www.punchdeckingstore.co.uk/aluminium-ramp-decking-2500mm-305mm-p-26.html
i assume theres steel 'support' underneath?
________________________
stevebubs
posted on 10/5/10 at 12:58 AM |
Marine ply is the stuff to use...
Dave Ashurst
posted on 10/5/10 at 02:58 AM |
Expanded metal decking perhaps?Image deleted by owner
Danozeman
posted on 10/5/10 at 06:33 AM |
I was going to redo it with patio decking.
Dan
posted on 10/5/10 at 07:36 AM |
I used tongue and grooved flooring on mine, should last about 5 years and easy and cheap enough to replace
posted on 10/5/10 at 08:37 AM |
I'd do it properly and do it once with some 12mm DMP plywood.... Cheaper in the long term...
skinned knuckles
posted on 10/5/10 at 10:41 AM |
12mm thames marine board. expensive but will last forever.
A man isn't complete until he's married, then he's finished
