pajsh
| posted on 11/5/10 at 07:40 AM |
Any Landrover Experts here - Gearbox Problem??
Eldest has a problem with his L reg Disco in that the gearbox chatters when in neutral and reverse is very hard to engage.
Garage says it needs a new box and it doesn't look too tricky, just messy.
Anyone know a good source for a 2nd hand disco box?
I used to be apathetic but now I just don't care.
| posted on 11/5/10 at 07:54 AM |
These boxes are very sensitive to correct lubrication.
NigeEss
| posted on 11/5/10 at 08:00 AM |
Early boxes had issues with oil feed to the output shaft, cured by a cross drilled replacement.
Could explain the chattering. If all other gears select ok have you checked clutch for fluid or
adjustment ?
It's the only gear without synchro so will be more difficult to select.
dazzx10r
| posted on 11/5/10 at 10:16 AM |
Have a look on landyzone.
pajsh
| posted on 11/5/10 at 10:37 AM |
Thanks will try landyzone at lunchtime.
As the forward gears bang a bit into gear I guess it may be a clutch issue.
I'll have a drive tonight and see how it feels.
Bleeds oil quite a bit so might be worth checking the oil levels.
boggle
| posted on 11/5/10 at 11:26 AM |
synchro.....it sounds like an lt77 box...
u2u me for details
Lightning
| posted on 11/5/10 at 03:14 PM |
Oooo i have one of those in my garage. Apparently it was reconditioned. Its a Disco LT77 box. give me a U2U
[Edited on 11/5/10 by Lightning]
