cd.thomson
| posted on 18/5/10 at 05:56 PM |
Ford ka red brown gunge
Hi guys,
a friend has just got out to her car and found red/brown gunge (she might mean a viscous liquid) over her clutch pedal.
Diagnosis?
Craig
| posted on 18/5/10 at 05:58 PM |
Dog pooh
cd.thomson
| posted on 18/5/10 at 06:01 PM |
Any mechanical fluid possibilities? Hydraulic m/c? Brake fluid? Powersteering fluid? Clutch m/c?
I know nothing about these cars!
[Edited on 18/5/10 by cd.thomson]
Craig
dinosaurjuice
| posted on 18/5/10 at 06:12 PM |
i think ka's have a clutch cable. and the brake MC is on the passenger side of bulkead.
have to agree with dog pooh sounds most likely!
balidey
| posted on 18/5/10 at 06:36 PM |
over greasing of the pedal linkage
Dutch bears have terrible skin due to their clogged paws
TGR-ECOSSE
| posted on 18/5/10 at 07:10 PM |
The clutch master cylinder is located just above the clutch pedal under the dash so that might be a clue
plentywahalla
| posted on 18/5/10 at 07:12 PM |
How about heater matrix leaking rusty water? does it dissolve in water? therefore not oil based problem
dlatch
| posted on 18/5/10 at 07:59 PM |
heater matrix would be my bet how old is it?
adithorp
| posted on 18/5/10 at 08:43 PM |
Either, clutch fluid, but thats unlikely to be described as "red" (but not unknown), or, coolant from the heater matrix which would be
red.
adrian
http://jpsc.org.uk/forum/
beaver34
| posted on 18/5/10 at 08:53 PM |
heater matrix leak i would bet, if it was clutch you would have the low fluid on the dash as they all feed from same res
iank
| posted on 18/5/10 at 09:10 PM |
Try the sniff test. If is smells of rust it's probably heater matrix, if it smells of brake fluid then clutch cylinder, if you retch and throw
up it's dogs egg.
Anonymous
tomblyth
| posted on 18/5/10 at 10:06 PM |
wrong time of month?
| posted on 19/5/10 at 08:14 AM |
Not unkown for the scuttle plenum chamber to rust through on Fiestas ---
