Oliver Jetson
posted on 5/6/10 at 03:07 PM |
Locost Hillclimb/track/race car - Yamaha R1 engined
For sale is my Locost race/hillclimb/sprint car powered by an R1 engine.
I'm back from the States now so had a chance to take some better pictures.
Specification:-
Chassis:-
Built to the Ron Champion spec for use in the year 2000 Locost race series
Originally fitted with a 1300 Ford XFlow engine
CDS roll bar
Bodywork:-
Aluminium panelling with GRP front and rear wings.
Full set of front and rear lights
Suspension:-
Avo shocks with adjustable damping
Brakes/Wheels:-
Front Ford M16 calipers with Greenstuff pads
Braided brake hoses
Rear drums (incorporated in to the Escort live axle)
Adjustable brake bias bar
Separate front and rear brake cylinders
Remote brake fluid reservoirs
Ford 13” four spoke Mk2 Escort wheels with Yokohama A509 tyres
Drivetrain:-
Two piece propshaft with centre bearing and sliding joint
Mk2 Escort live axle
Engine/cooling/fueling:-
1999 4XV Yamaha R1 engine (carbs) with sump baffle plate
Custom triangulated engine mounts with Powerflex bushes
Standard airbox modified to run the other way around to fit better in the car
K&N air filter
MK Engineering 4 in to 1 exhaust manifold and re-packable silencer
Crank case breather filter
Second Yamaha clutch diaphragm plate fitted and an MNR clutch cable
New YTX14 bike battery
New NGK spark plugs
Fresh 5W40 synthetic oil
Facet steady state fuel pump
Fuel pressure adjuster
Aluminium fuel tank
Cooling system consists of a multitude of silicon hose/aluminium connectors
Greddy inline adaptor to house water temperature sensor
Large radiator with electric fan on a temperature switch
Interior:-
Driver’s side is a covered, contoured Caterham race seat that provides excellent hold (wouldn't mind keeping this as it fits me perfectly!).
Willans 4 point single seater 3” harness on driver’s side with aircraft quick release and lightweight adjusters (FIA date 2008 so no longer valid for
competition).
Passenger side is a basic GRP shell seat with a basic 4 point harness
Manual use fire extinguisher in passenger footwell
Mountney steering wheel
Racetech speedo, water temperature, oil temperature and pressure (not connected with this engine). Elliot tachometer.
Diff oil warning light
Neutral Light (for easily identifying neutral when you come to a stop)
Various toggle switches for the lights/fuel pump etc.
Condition:-
It’s a used race car, not a show room stunner. The GRP parts have various stone chips and scrapes and the paint is faded in places from being rubbed
by the car cover when on my trailer. The chassis is painted with Hammerite which has flaked in a few places showing through some minor surface rust.
The aluminium panels have got some blemishes. However it is a presentable car.
Other Info:-
This car is not road legal. The history of it is that it was built and raced in the year 2000 for the 750mc Locost race series and used as a track day
car. I bought it in 2003 in its original spec with a 1300cc race prepared Ford Crossflow engine. I used the car in 2004 for hillclimbs and with the
crossflow engine this chassis with me driving managed a 69.48 second run at Loton Park hillclimb fending off a few 1600 Caterhams! In 2005 I then
decided to change it to use the R1 engine as a bit of a project and to produce a car that could compete with more serious kit.
It’s been a slow project and took me till the end of 2008 to get it to a running stage. It was then garaged until the beginning of this year when I
found time to get back to it. It’s had a clean and tidy up with new oil/coolant and started first time when I fitted the new spark plugs and battery.
It has not yet been run in anger with the R1 engine, only run on a private road to check everything works ok.
It would be a good project if you want a working race car to convert for road use or use it as a dedicated race/track car. I'm looking to move
to a Westfield SEiW or Caterham road/race car hence the reason for sale.
Price:-
£4500 with sensible offers considered
Contact:-
Mobile 07989830651
or PM on here
Car located in Wiltshire
Thanks,
Oli
Oliver Jetson
posted on 7/6/10 at 03:23 PM |
To the top. I have the front lights too but just haven't fitted them in the above pictures.
Oliver Jetson
posted on 10/6/10 at 05:02 PM |
I can be around this weekend for anyone wishing to come and have a look
Oliver Jetson
Oliver Jetson
posted on 30/6/10 at 09:59 AM |
I'm dropping the price to £3500
I need the garage space for a new toy, plus I'd like to be able to see some of the summer in a road legal car!
posted on 30/6/10 at 10:02 AM |
Very cheap indeed.
Do you think it would take much to get through IVA?
Oliver Jetson
posted on 30/6/10 at 10:12 AM |
I think the biggest cost for IVA would be fitting a reverse box. I imagine it would then be a case of fettling smaller items like radii, dash layout
etc.
Oliver Jetson
posted on 7/7/10 at 05:34 PM |
Now sold, on its way to Ireland.
Time to look for a Westfield
